Run Farming Simulator 2015 without Disc: Solutions for Lost or Missing Game Discs
balonika3 27123 18
Can I run Farming Simulator 2015 without the original disc if the game is already installed and only the disc is missing?
Legally, no: without the original disc there is no lawful way to bypass the disc check [#16763090] The thread says the only practical workaround is an unofficial no-cd/no-dvd fix: find the matching Farming Simulator 2015 fixed files on GameCopyWorld, make sure the version matches your installed game (for example 1.2.0.0 / MULTI6), unpack the archive with something like 7-Zip, and copy the replacement files into the game folder, overwriting the originals [#16764770][#16764872][#16765025] Another option mentioned is using a mini-image mounted in Daemon Tools [#16764864] One reply also notes that this kind of file replacement is a license/EULA issue and may be illegal [#16764953]
  • #1 16763073
    balonika3
    Help: 1336
    Rate: 3762
    Hello. I have a question - is it possible to run a game that requires a disc in the drive without this disc? I am explaining - it is a normally purchased game, I have an original box and a booklet with instructions and code. The game is installed on the computer, but the disc is lost somewhere. The house turned upside down and the plate is gone. When trying to start up, the message "Place the game disc in the drive" pops up. The game is "Farming Simulator 2015". Can you do something? Thank you in advance.
  • #2 16763090
    helmud7543
    Help: 1216
    Rate: 1564
    Legally without getting the original disc - no.
  • #3 16763127
  • #4 16763128
    Kaliber PC - Service
    Help: 50
    Rate: 69
    All in all, for me it is also a good question ... But on the other hand - do you download the crack to legally installed game to which you have been entered legally purchased code , this as well piracy :?: Theoretically (if you actually have the code) , it should not be illegal ... or not? :lol:
    But I'm wondering ... author , you have box , you have instructions with code , a you do not have a disc ? What is this happening ??? :D
    Added after 43 [seconds]:
    HyHy, I think I'm a friend drobok he managed to solve my doubts ... :D
    Konstantego Damrota 5, Radlin, 44-310 | Tel.: 692XXXXXX (Show) | Company Website: https://www.kaliberpc-service.pl/
  • #5 16763171
  • #6 16763185
    balonika3
    Help: 1336
    Rate: 3762
    JasnyKris wrote:
    Author, you have a box, you have instructions with the code, and you do not have a CD? What is this happening ???
    Nothing happens. She died and already. As for the box and instructions with the code, I can upload a photo for the doubters.
  • #7 16764396
    Help: 50
    Rate: 69
    But calmly! I do not accuse or anything, I am sometimes surprised by certain situations. :)
  • #8 16764734
    balonika3
    Help: 1336
    Rate: 3762
    JasnyKris wrote:
    But calmly!
    Oh, I'm calm.
    drobok wrote:
    Everything is possible, enter "gamecopyworld Farming Simulator 2015" in google. You can change the file in the game folder and you can play without a disc.
    Can you expand it? Under this slogan I found a website with a lot of links. But I have no idea what to do about it. Can you help?
  • #9 16764770
    lekto
    Help: 294
    Rate: 299
    You enter the gamecopyworld site, enter the name of the game on the right, a list of games appears, find yours. In the index you have files related to the game, in your case you are looking for no-cd / no-dvd, in parentheses you have the given language version and the name of the game is the version (if you have a different version you are doing upgrade / downgrade). A few links, moves you down, you click on a floppy disk, tralalala ...
  • #11 16764864
    enhanced
    Help: 964
    Rate: 884
    A bit of mini image mounted in daemon tools.
  • #12 16764872
  • #13 16764889
    balonika3
    Help: 1336
    Rate: 3762
    Unfortunately, it moves to a page where you have to give a phone number, advertise in new windows, etc. Any more normal way exists?
  • #14 16764904
    enhanced
    Help: 964
    Rate: 884
    Something is probably going wrong.
  • #15 16764924
    balonika3
    Help: 1336
    Rate: 3762
    Okay. On another page I found and downloaded a file named "FARMING.SIMULATOR.15.V1.2.ALL.CODEX.NODVD.ZIPd". This is kind of some codex no dvd. What to do with it?
  • #16 16764953
    helmud7543
    Help: 1216
    Rate: 1564
    Send link to PW, I will try to look at it. And scan the anti -irection. As for legality - morally, of course, you do not steal, unfortunately you are breaking the law. Such a world of exploitation. You do not buy the program, only the right to use it, to the extent that is provided for in the license.
  • #17 16764986
    balonika3
    Help: 1336
    Rate: 3762
    @drobok Something came: "rzx-ls15int12x86c". What's next?
  • #18 16765025
  • #19 16765084
    balonika3
    Help: 1336
    Rate: 3762
    Thanks to colleagues! It worked! I made a copy of the original file (maybe sometime this disc will be found). Unfortunately, there is no "Help" here, so I give you the pluses. Thanks and best regards.
    Edit: the limit of pluses is exhausted. :cry:
The discussion revolves around the possibility of running "Farming Simulator 2015" without the original game disc after it has been lost. Users provide various solutions, including using a "no-CD" or "no-DVD" crack, which allows the game to run without the disc. While some participants express concerns about the legality of such methods, others argue that having a legitimate copy of the game and its code should justify the use of these workarounds. Instructions are shared on how to find and implement these solutions, including downloading files from gamecopyworld and modifying game directories. Ultimately, the original poster successfully applies a no-DVD patch, allowing them to play the game without the disc.
TL;DR: A 3‑step no‑disc workaround (unzip, copy, replace) solved Farming Simulator 2015 launch errors—“It worked!” for the thread author. [Elektroda, balonika3, post #16765084]
Why it matters: If you lost your FS15 DVD, this FAQ shows practical, forum‑tested options and risks so you can decide safely and legally.
Can I run Farming Simulator 2015 without the original disc?
Forum guidance says no, not legally, without the original disc. License terms tie use to the disc, even if you own the box and code. “Legally without getting the original disc – no.” We explain technical workarounds below, but your local laws and the game’s EULA govern use. [Elektroda, helmud7543, post #16763090]
What options did the community use when the FS15 DVD was lost?
Two approaches appear: using no‑CD/fixed files matched to your FS15 version, and using a mini‑image mounted in a virtual drive tool like DAEMON Tools. Both attempt to satisfy the disc check at launch. Success depends on version matching and source quality. [Elektroda, enhanced, post #16764864]
Which FS15 version did the successful no‑disc workaround target?
The author reported Farming Simulator 15 version 1.2.0.0. Use fixes that explicitly match 1.2 to avoid crashes or refused launches. Version mismatches are a common failure cause. [Elektroda, balonika3, post #16764815]
Is using a no‑CD crack or fixed files legal if I own the game?
A poster notes it still breaks the license/EULA even if you bought the game and code. Another adds you purchase the right to use software as licensed, not unrestricted ownership. We cannot provide legal advice; check local law. [Elektroda, helmud7543, post #16764953]
What is a “mini‑image” and when would I use it?
A mini‑image is a small disc image that emulates the original DVD’s presence for the game’s check. You mount it with tools like DAEMON Tools so the game sees a virtual drive. It’s an alternative to replacing files. [Elektroda, enhanced, post #16764864]
What is a “no‑CD/fixed file” for FS15?
It’s a replacement executable or related files that remove or bypass the disc check. You copy them into the FS15 install directory, replacing originals after backing up. One poster called these “no‑cd/no‑dvd” files. [Elektroda, lekto, post #16764770]
How do I apply a fixed‑file no‑disc solution step‑by‑step?
  1. Extract the downloaded archive with a tool like 7‑Zip.
  2. Open your FS15 install folder (via the game icon’s Properties > Open file location).
  3. Copy extracted contents into the folder and allow Replace; keep a backup of originals. “It should work” afterward. [Elektroda, Anonymous, post #16765025]
I downloaded a file named rzx‑ls15int12x86c. What do I do?
That’s an archive. Extract it first, then copy the contents into the FS15 install directory, replacing files. Keep backups so you can revert. This mirrors the working approach described in the thread. [Elektroda, Anonymous, post #16765025]
How do I avoid scammy download pages and pop‑ups?
One user hit pages asking for a phone number and throwing pop‑ups. Back out immediately, avoid submitting any data, and look for alternate mirrors or sources mentioned by posters. Treat aggressive redirects as red flags. [Elektroda, balonika3, post #16764889]
There’s no Polish fixed file listed. Will the international (MULTI6) one work?
A poster suggested starting with the v1.2 MULTI6 fixed files for the disc version. Match your game version, then test. If it fails, consider version upgrade/downgrade per the index guidance. [Elektroda, Anonymous, post #16764872]
What if replacing files doesn’t work the first time?
Check that your FS15 version exactly matches the fixed files’ version, and restore your backups. Language mismatches or wrong builds can cause failures. Try a mini‑image method if file replacement fails. [Elektroda, balonika3, post #16764815]
Did anyone confirm success running FS15 without the disc?
Yes. After copying replacement files and backing up the original executable, the author reported success: “It worked!” This validates the process for FS15 1.2.0.0 on their setup. [Elektroda, balonika3, post #16765084]
What’s the quickest way to find the FS15 install folder?
Right‑click the game’s desktop or Start menu shortcut and choose Properties, then Open file location. Copy the fixed files there and confirm Replace. Keep a backup of the original files first. [Elektroda, Anonymous, post #16765025]
Any expert tip on the legal boundary here?
One contributor summarized the boundary clearly: “Legally without getting the original disc – no.” If you proceed for personal use, understand the license violation risk and potential consequences. [Elektroda, helmud7543, post #16763090]
