Choosing Between Full HD or 4K TV: 50-55 inches, 2500 PLN Budget, Samsung or Panasonic
5403 18
Which 50–55-inch Samsung or Panasonic TV should I choose for evening Netflix and HDMI laptop use at 2–3 meters, and is Full HD preferable to a cheap 4K model?
For this use, the thread favors a Full HD Samsung with a VA panel, especially the UE55M5672AU if the budget can reach about PLN 3,000. [#16712586] The 55M5672 was specifically recommended as a 55-inch option, while the model suffixes such as AU or AW generally indicate housing or market details rather than important technical differences. [#16712959] [#16721464] The Panasonic TX-50DS630E is another strong option because it has a 120 Hz panel, but availability may be unreliable because stores reportedly list it despite not having stock. [#16713593] [#16713632] If the Panasonic cannot be obtained, the Samsung UE55K5572 is a suitable fallback: it has a VA panel and 60 Hz is considered sufficient for films and series when sports are not a priority. [#16719717]
  • #1 16712506
  • #2 16712586
    Ludwik XVI
    Help: 1325
    Rate: 788
    See on Samsung FHD M5672 series on VA matrix. 50 inches, I think, enough money.
    Unfortunately, the 55-inch version is closer to PLN 3,000.
  • #3 16712593
  • #6 16713593
    Ludwik XVI
    Help: 1325
    Rate: 788
    Of the 50DS630e definitely mentioned - it is a 120Hz model.
  • #7 16713632
    skoroszyt12
    50DS630E only from the display. They appear on the page that new ones are available, but when you go to the store they will say that they are not there. The seller said that a lot of people come and ask about these TVs, so I wouldn't be surprised that they treat it as a lure :)
  • #8 16719464
  • #9 16719717
    Ludwik XVI
    Help: 1325
    Rate: 788
    If you don't get DS630e then you can take Samsung-ue55k5572.
    Although 60Hz but you still do not watch sport so enough. For the movies / series in the evening, the VA matrix will be more useful.
  • #10 16720757
  • #11 16721464
    Ludwik XVI
    Help: 1325
    Rate: 788
    Shortcuts are usually the color of the housing, etc. No technical significance.
  • #12 16721501
  • #14 16722388
    Mariano11
    Help: 57
    Rate: 43
    The Philips 6561 is also on a 120 Hz matrix. You can also afford it, too.
  • #16 16723597
    Ludwik XVI
    Help: 1325
    Rate: 788
    In my opinion the best samsung-ue55m5672au
  • #17 16724452
    Mariano11
    Help: 57
    Rate: 43
    Why exactly this? Thread terribly well worn.
  • #18 16724762
  • #19 16726488
    Mariano11
    Help: 57
    Rate: 43
    Watch Ambiligta and Android TV live :)
The discussion revolves around selecting a TV in the 50-55 inch range with a budget of 2500 PLN, focusing on Full HD versus 4K options. The user previously owned a 46-inch Full HD Samsung and seeks a model suitable for evening viewing, preferably with a VA matrix. Recommendations include the Samsung FHD M5672 series and Panasonic TX-50DS630E, with discussions on the benefits of 120Hz refresh rates and VA panels for better contrast. The user considers increasing the budget to 3000 PLN for better options and evaluates several Samsung models, including UE55K5572, UE55K5600, and UE55M5672, ultimately leaning towards the UE55M5672 due to its features and performance. The conversation also touches on the significance of model suffixes and the availability of models in stores.
TL;DR: For evening viewing at 2–3 m, a 60 Hz VA Full HD Samsung was advised; “the VA matrix will be more useful.” One stat: 60 Hz. [Elektroda, Ludwik XVI, post #16719717] Why it matters: This FAQ helps shoppers pick a 50–55" TV on a 2,500–3,000 PLN budget without overpaying for features they won’t use.
Full HD or cheap 4K for 50–55 inches on ~3,000 PLN?
Advisers steered buyers to Full HD VA Samsungs for evening movies and series. A 60 Hz VA panel was called sufficient if you don’t watch sports. Prioritize panel type and contrast over budget 4K at this price. [Elektroda, Ludwik XVI, post #16719717]
What screen size fits a 2–3 m viewing distance?
The shopper targeted 50–55 inches for a 2–3 m setup and evening use. That range matched their viewing habits and room size and was supported throughout the thread’s recommendations. [Elektroda, Anonymous, post #16719464]
Which 55-inch model around 3,000 PLN was recommended?
Samsung 55M5672 was cited as available at about 3,000 PLN and linked as a tested option. It fits the 55-inch target and the Full HD preference discussed. [Elektroda, Ludwik XVI, post #16712959]
Is Panasonic TX-50DS630E a good pick?
It was endorsed as a 120 Hz set, making it strong for motion handling. For buyers who value smoothness, that spec stood out among the listed choices. [Elektroda, Ludwik XVI, post #16713593]
Why can’t I find the Panasonic TX-50DS630E in stock?
One user reported stores showing it online but lacking stock in person, suggesting units might be display-only. Treat it as a potential availability trap and verify in-store. [Elektroda, skoroszyt12, post #16713632]
If the DS630E isn’t available, what Samsung alternative fits?
Go with Samsung UE55K5572. It is a 60 Hz VA model, and the adviser said that’s enough for films and series when sports aren’t a priority. [Elektroda, Ludwik XVI, post #16719717]
Do Samsung UE55K5572/UE55M5672 use VA panels?
Yes. The adviser confirmed VA and suggested verifying any model’s panel on DisplaySpecifications before purchase. This helps avoid panel-lottery surprises. [Elektroda, Ludwik XVI, post #16721536]
Do suffixes like AU or AW change performance?
No. Those suffixes typically indicate cosmetic differences such as color. They have no technical significance for picture or motion specs. [Elektroda, Ludwik XVI, post #16721464]
Between UE55K5572, UE55K5600, and UE55M5672, which is best?
The thread’s final pick favored Samsung UE55M5672AU. It aligned with the size, budget, and VA goals while keeping the interface buyers liked. [Elektroda, Ludwik XVI, post #16723597]
Is Philips 6561 worth a look?
Yes. A participant flagged Philips 6561 as a 120 Hz option within reach of the stated budget. Consider it if you want higher native refresh. [Elektroda, Mariano11, post #16722388]
How can I verify a TV’s panel type before buying?
  1. Note the exact model code on the product page or box.
  2. Open DisplaySpecifications and search the model.
  3. Confirm “Panel Type” (e.g., VA) and refresh rate, then buy. [Elektroda, Ludwik XVI, post #16721536]
Will Tizen cover Netflix and common apps?
The buyer preferred Samsung’s Tizen and required Netflix. Verify the app in-store on the exact model and region before checkout to avoid surprises. [Elektroda, Anonymous, post #16724762]
Upgrading from UE46D6500: is the jump meaningful?
The user wanted a larger screen and modern apps the older set lacked. Moving to 55-inch K5572/M5672 meets those goals and adds the VA benefits discussed. [Elektroda, Anonymous, post #16720757]
What price difference should I expect between 50 and 55 inches in FHD Samsung?
Advisers noted 50-inch fits lower budgets, while 55-inch versions land closer to 3,000 PLN. Plan financing accordingly when stepping up in size. [Elektroda, Ludwik XVI, post #16712586]
Do I need 120 Hz if I rarely watch sports?
No. The adviser stated a 60 Hz VA set is enough for films and series. “The VA matrix will be more useful” for evening viewing. [Elektroda, Ludwik XVI, post #16719717]
