Furnace Blower Issue: Difficulty in Opening/Closing, Adjusting Screws & Nuts, Weak Force & Load
sopin 7071 2
  • Weak blower force prevents screw return
    #1 16773965
    sopin
    Hello, I have such a problem, the stove blower does not close or close, I have to set the screw with my finger on the open and leave it like that, because when the load is too heavy, the screw does not rise (the blower has no force), and when it is too small, the screw does not it returns .. I tried to tighten the nuts, but the effect was that, for example, the blower slightly lifted the bolt without return.
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Nuts serve as counters. You need to adjust the length of this screw so that when the blower is turned on, the flap will rise, and when turned off, it will fall.
  • #3 16774212
    Loker
    Help: 575
    Rate: 721
    As already mentioned - enter the type of blower.
    If it's something like WPA-120 and proportional control - you won't adjust the flap. It is basically two-state - either open or closed. In addition, there are vibrations during work ... I have removed the flap at home - assuming that if there is a strong chimney draft, it will open it anyway.
