Best Front-Load Washing Machine up to PLN 1500: Indesit WIE107 Successor, Interchangeable Bearings
klkck 10551 13
Which front-loading washing machine under PLN 1,300–1,500 should I buy as a replacement for an Indesit WIE107, preferably a normal-depth model with replaceable bearings?
Look at Bosch WAE/WAN models or Amica models with a detachable drum, because those were the most supported choices for your budget and requirement set [#16782996][#16779989] The Bosch WAE line is said to be made in Poland and to have replaceable bearings, and the newer WAN line also has replaceable bearings; one example given was the WAN2826EPL, while WAY and WAS models mostly also have replaceable bearings but are a higher tier [#16782996] A specific Bosch recommendation was the WAE 2026KPL [#16782576] Amica was also recommended because it has a dismountable drum, replaceable bearings, a normal motor, and available parts [#16779989] Models such as Amica AWB510L and AWG6102SL were praised as quiet, economical, practical, easy to use, with 6 kg capacity and 1000 rpm [#16776254][#16776325]
  • #1 16775594
    klkck
    Rate: 36
    Until the weekend I have to buy the successor of Indesita WIE107 up to PLN 1,300 - PLN 1,500. It is to be loaded from the front preferably of normal depth and with interchangeable bearings. What are you looking at?
  • #2 16776254
    porazony_pradem
    Rate: 16
    I could recommend two washing machines in this price range:
    BOSCH 6 series VarioPerfect WLT24460PL
    or
    Amica AWB510L
    Both appliances are a very good choice, quiet, economical and practical. Briefly. In addition, I recommend checking the opinions of the equipment, they are positive.
  • #3 16776325
    OlekPek
    Rate: 17
    porazony_pradem wrote:
    or
    Amica AWB510L
    I support.
    Though I would recommend Amica AWG 6102SL .
    Loaded from the front, cheap, it holds 6kg, 1000 revolutions, feathers quickly and accurately (even with short programs there is no problem with everything), I personally think that it is really quiet on what I care ... and easy to use.
  • #4 16777767
    klkck
    Rate: 36
    So I did some forum yesterday and came to the conclusion that buying a washing machine today is a lottery, unfortunately ...
    I was focused on Bosch, but I see that he is troubled by the same problems as other producers ...
    The next thing I noticed is the recommendation on the Amica and LG washing machines unless I'm wrong ...
    Listen, can Amice really be trusted?
    And are LG machines really okay? Here I would be afraid of the drive. Motor on the drum and still inverter ...
  • #5 16778778
    Katarzyna1212
    I'm pinning the subject. However, I would care about higher revolutions and a large dismountable drum (so that the bearing can be replaced without any problems - just in case). It does not have to be completely new.
  • #6 16779989
    klkck
    Rate: 36
    Probably hardly anyone looks here :) ...
    I will be inclined towards Amica ...
    Undressed drum, interchangeable bearings, normal motor, no molded part and availability of parts ...
    I was for the sake of Bosnia, but it is not the quality and failure-free as it used to be. A friend bought a washing machine from this manufacturer and had it for a short time. It poured down every now and then. In the end, he bought a new ... also Bosch :) ...
  • #7 16780043
    Dawid Weiss
    Rate: 13
    It is worth knowing what country the washing machine was manufactured in ;)
  • #8 16781873
    r103
    Level 37  
    Help: 283
    Rate: 968
    Generally, accountants in the "Headquarters" of a washing machine concern - issue guidelines on material savings and planned non-repairs - applicable in all countries where they are produced ...
  • #9 16782034
    klkck
    Rate: 36
    Gentlemen, slowly, i.e. on days I have to buy something. Indesit sounds like a starting jet ...
    Short and to the point...
    Which producer / which model should Amika take into consideration?
    In which Amica model to aim?
  • #10 16782576
    Dawid Weiss
    Rate: 13
    I would personally recommend BOSCH WAE 2026KPL
    Accountants plan and paper will accept everything. The production hall is governed by its own laws. :D
  • #11 16782695
    Katarzyna1212
    WAE or made in Poland and with a detachable drum? I remember well?
    And what do you think about WAY or WAS? They have a bigger drum capacity ...
  • #12 16782996
    agdrtv.info
    Help: 13
    Rate: 25
    Yes, the WAE line is manufactured in Poland, and they have interchangeable bearings. Same as the new WAN line. With greater capacity is e.g. WAN2826EPL .
    WAY and WAS mostly have interchangeable bearings, but this is a higher shelf.
  • #13 16785174
    Tobisz
    My wife chose Amica, it is 40-45 cm deep, so flat and a large load and a very large door. It cost thousands of zlotys with pennies, good, easy to use, and even guys can not say they can not turn on :D It meets our expectations.
  • #14 16786384
    klkck
    Rate: 36
    What Amica did you buy?
The discussion revolves around finding a suitable successor to the Indesit WIE107 washing machine within a budget of PLN 1,300 - PLN 1,500. Participants recommend several models, highlighting the importance of features such as front-loading, normal depth, and interchangeable bearings. Key suggestions include the Bosch WAE 2026KPL, Bosch 6 series VarioPerfect WLT24460PL, Amica AWB510L, Amica AWG 6102SL, and Amica models with detachable drums. Concerns about reliability and quality of brands like Bosch and Amica are raised, with some users expressing skepticism about the inverter motors in LG machines. The conversation emphasizes the need for higher revolutions and ease of maintenance, particularly regarding drum disassembly for bearing replacement.
TL;DR: Looking for a front‑loader with replaceable bearings under PLN 1,500? A 6 kg, 1000 rpm Amica was praised as “really quiet” and easy to use. [Elektroda, OlekPek, post #16776325]
Why it matters: This FAQ helps value‑seekers choose a front‑load washer with serviceable bearings and sensible specs without overpaying.
What’s the best front‑load washing machine under PLN 1,500 with replaceable bearings?
The thread’s working shortlist is Bosch WLT24460PL, Amica AWB510L, and Amica AWG 6102SL. Users highlight quiet, economical operation and straightforward controls. If you need a proven pick with serviceable design, also consider Bosch WAE/WAN lines, which are noted for interchangeable bearings. Start by matching depth to your space, then target 6 kg capacity and 1000 rpm for balanced performance and noise. “Quiet, economical and practical” summarizes the consensus at this budget. [Elektroda, porazony_pradem, post #16776254]
Is Amica a trustworthy choice for a front‑loader in this budget?
Yes, multiple posters recommend Amica in this price range. One owner cites a 6 kg, 1000 rpm Amica as quiet and accurate even on short programs. Another highlights a slim 40–45 cm Amica with large load and large door, meeting family needs and budget. These comments align with the request for interchangeable bearings and simple serviceability. If you value quiet cycles and easy use, Amica fits well. [Elektroda, OlekPek, post #16776325]
Are LG Direct Drive/inverter washers a risk?
The original poster expressed concern about LG’s motor‑on‑drum inverter design but did not receive counter‑evidence in the thread. The discussion steers toward Amica and Bosch models instead. If you are cautious about long‑term serviceability, focus on models explicitly noted for replaceable bearings. The thread’s practical advice centers on conventional drive designs and accessible parts. [Elektroda, klkck, post #16777767]
Which Bosch series have interchangeable bearings and where are they made?
The Bosch WAE line is noted as Poland‑made with interchangeable bearings. The newer Bosch WAN line also has interchangeable bearings, with a highlighted higher‑capacity model WAN2826EPL. If you want a larger drum while keeping serviceability, look to WAN. For a value buy, WAE remains attractive when available used or as remaining stock. [Elektroda, agdrtv.info, post #16782996]
Which specific Amica models were recommended and why?
Amica AWB510L and AWG 6102SL were recommended for quiet, economical washing and easy operation. One user stresses that AWG 6102SL handles quick programs accurately and stays quiet, which helps in small apartments. At 6 kg and 1000 rpm, it balances capacity with gentle spin speeds that protect fabrics. These traits make Amica a strong budget pick. [Elektroda, OlekPek, post #16776325]
Do slim (40–45 cm) front‑loaders still take a large load?
Yes. A poster reports choosing an Amica that is 40–45 cm deep yet offers a large load and very large door. It met family needs and stayed around “a thousand‑plus PLN.” Slim designs help in tight bathrooms while keeping drum volume practical. Confirm the actual drum liters and door opening if you have bulky items. [Elektroda, Tobisz, post #16785174]
How important is the country of manufacture for washers?
One participant advises that it’s worth knowing the country of manufacture. This can hint at parts sourcing and service practices. Practical tip: check the rating plate near the door or back panel at the store. As one commenter notes, “It is worth knowing what country the washing machine was manufactured in.” Use this to compare similar models. [Elektroda, Dawid Weiss, post #16780043]
Are modern Bosch machines still reliable?
Opinions vary. The original poster planned for Bosch but reported a friend’s unit with recurring leaks, eventually replaced by another Bosch. This is a reminder to check series and production origin, and to prefer models with replaceable bearings. Edge case: even reputable brands can have early failures, so retain receipts and register warranties. [Elektroda, klkck, post #16779989]
Which Bosch models balance capacity and serviceability?
Consider Bosch WAN for larger drums with interchangeable bearings, with WAN2826EPL cited as an example. If you find a WAE in good condition, it’s also Poland‑made and service‑friendly. Higher‑tier WAY/WAS mostly have interchangeable bearings too, but they belong to a higher price shelf. Match capacity to household size before paying for extras. [Elektroda, agdrtv.info, post #16782996]
What does “interchangeable bearings” mean, and why should I care?
It means the drum bearings can be replaced without swapping the whole tub. Serviceable bearings lower lifetime costs and extend machine life. Bosch WAE and WAN lines are explicitly noted with interchangeable bearings. If you wash often, this feature can save significant money beyond the purchase price. It’s a key differentiator at this budget. [Elektroda, agdrtv.info, post #16782996]
How do I verify a washer’s bearings are replaceable (3‑step check)?
  1. Identify the exact series (e.g., Bosch WAE/WAN) on the nameplate.
  2. Search the service note or manual for “replaceable bearings” or split tub.
  3. Confirm with retailer or service center before purchase. "It is worth knowing what country the washing machine was manufactured in," and model details matter similarly. [Elektroda, Dawid Weiss, post #16780043]
Is there a consensus pick from the thread?
The thread trends toward Amica for price‑to‑value and Bosch WAE/WAN for serviceability. Specific endorsements include Amica AWB510L and Amica AWG 6102SL for quiet, accurate washing. For Bosch, WAE/WAN lines are favored due to replaceable bearings and known origins. Choose based on depth constraints and desired drum size. [Elektroda, porazony_pradem, post #16776254]
Did anyone confirm which Amica model they finally bought?
A follow‑up question asked which Amica was purchased, but no final model was posted in the captured thread. If you need a similar slim, large‑door unit, consider the noted Amica options and verify depth on the spec sheet. Use the guidance here to finalize your shortlist. [Elektroda, klkck, post #16786384]
Are fast programs accurate on budget machines?
One owner reports the Amica AWG 6102SL washes quickly and accurately, even on short programs, and remains quiet. For light soil, short programs save time and energy. Always adjust detergent for short cycles to avoid residue. Watch load size to maintain spin balance. “It is really quiet,” the user adds, supporting confidence in daily use. [Elektroda, OlekPek, post #16776325]
What if I want higher spin speeds and a larger, split drum?
A poster asked for higher rpm and a large, dismountable drum for easy bearing replacement. Bosch WAY/WAS are mentioned as higher shelf and mostly with interchangeable bearings, while WAN offers larger capacity within a midrange bracket. Balance fabric care with spin speed; 1000 rpm already reduces drying time significantly. [Elektroda, agdrtv.info, post #16782996]
Is buying a washer today just a lottery?
The OP felt that way after research, citing mixed Bosch experiences and turning toward Amica for replaceable bearings and parts availability. Reduce risk by verifying series, serviceability, and country of manufacture before purchase, and by checking retailer reviews. Keep documentation for warranty claims if early defects arise. [Elektroda, klkck, post #16779989]
