Comparing Front-Load Slim Washing Machines: LG, Amica, Bosch & Elektrolux under PLN 1500
SKYFander 10446 10
Which slim front-load washing machines under PLN 1500 have replaceable bearings, especially among Electrolux, Sharp, and Bosch?
For front-load Electrolux washing machines, the thread says there is currently no model with a split tank; the bearings are replaced by cutting open the tank, so they are not normally user-replaceable [#20066647] An earlier reply also notes that Electrolux models with replaceable bearings are the top-loading ones, not the front-loaders [#18154923] Sharp is unclear: one reply says Sharp machines do not have replaceable bearings [#17109309], while another says Sharp comes from the same factory as Amica and in most cases has replaceable bearings [#17120319] Bosch is also inconsistent by model and year: some Bosch machines have a removable drum, but others have the bearing sunk into the rear part, so repair may require replacing half the tank or cutting it open [#17110097] So, the safest takeaway is that Electrolux front-loaders should be treated as non-repairable in this respect, Sharp needs model-by-model verification, and Bosch slim models are not guaranteed to have replaceable bearings [#20066647] [#17120319] [#17109309] [#17110097]
  • #1 17109048
    SKYFander
    Hello. My mother's current washing machine gave up its spirit yesterday, so I have to pick something new a little "quickly". Amount up to PLN 1,500, loaded from the front, up to a depth of 45 cm. I really care about replaceable bearings. I know that all Amici, LG and Bosche WLG, WLK and WLT washing machines have this advantage. Initially, I'm decided on LG, I like the inverter motor, the features and the opinions about these washing machines. But I prefer to have a broader view anyway. What is the situation with other manufacturers' drums / bearings in this price range? Unfortunately, apart from Amica, probably no producer boasts about it, so it's hard to get information, and on the Internet, on forums, there is information from years ago, and a lot could have changed. I mean mainly Elektrolux, because as far as I know it is popular in our country. Recently, I also noticed Sharp washing machines in the store, previously I did not even know that they were producing. What does it look like with them?
    Thanks in advance for your help.
  • #2 17109309
    qs300
    Help: 242
    Rate: 362
    Sharp washing machines do not have replaceable bearings, I had several models in the store last year and checked.
  • Bosch drums may require tank cutting for bearing replacement
    #3 17110097
    80x86
    I am not convinced if the Bosches you mentioned have a removable drum - I was looking for such information and I found contradictory data. This may depend on the year of manufacture - hence the inconsistency. Certainly, the disassembled drum also has the WAE series produced in Poland, but it is not slim :(
    But - some Bosch machines have a drum that can be dismantled, but the bearing is sunk in the rear part and you have to either replace "half" of the tank or cut.
    The second thing I already wrote about in another thread, after entering the word replacement of bearings in google or olx - we will get the results of many companies that replace bearings in all washing machines by cutting and welding plastic. provide a guarantee, and the cost of the order of PLN 200 plus a possible shipment of the washing unit. My father-in-law did it three years ago in 9-year-old Candy and so far it works, nothing is leaking.
    Currently, I am also considering Candy - they give a 5-year warranty :)
  • #4 17110232
    SKYFander
    I have info about it from one thread on the forum, probably from 2016, maybe something has changed during this time.
  • #5 17113876
    Pawel1812
    Help: 44
    Rate: 266
    Or maybe a colleague will repair a washing machine that gave up the ghost and probably has the desired, disassembled tank, instead of planning to replace the bearings in a new washing machine.
  • #6 17113981
    80x86
    Exactly - that might be the most sensible thing. Especially since it does not have to mean expensive repair. Here are two examples:
    The 1st washing machine knocked out the "differential" - the heater was released
    2.washing machine took water and solid, and when it was restarted it let out the water, scooped up again and stood again - broken motor brushes
    In both cases, both the cost and the difficulty are minor.
  • #7 17120319
    agdrtv.info
    Help: 13
    Rate: 25
    Electrolux unfortunately has no replaceable bearings.
    Sharp leaves the same factory as Amica washing machines, and in most cases they have replaceable bearings.
  • #8 18154923
    ProchuKRK
    Electroluxes have replaceable bearings, but ... those are loaded from the top :) If someone else was looking for info about it, here it is - https://www.prorankingi.pl/blog/aktualna-lista-pralek-z-wymiennymi-lofinansami/ - information confirmed by the producers, not taken from the hat and yet another curiosity about Samsung, because they have replaceable bearings, but not only do they need to be replaced then :)
  • #9 20066611
    gocania778
    Does the washing machine ELECTROLUX EW6F328WUP PerfectCare have replaceable bearings?
  • #10 20066647
    Kenworth 18
    Help: 2442
    Rate: 3749
    gocania778 wrote:
    Does the washing machine washing machine ELECTROLUX EW6F328WUP PerfectCare have replaceable bearings?
    Currently, no front-loading washing machine from this manufacturer has a disassembled tank. The bearings are replaced by cutting open the tank.
  • #11 20066669
    korystor
    Level 19  
    Help: 35
    Rate: 102
    80x86 wrote:
    they replace the bearings in all washing machines by cutting and welding the plastic.
    I add that I generally replace bearings in non-dismountable drums, but I do not stick together, but just twist so that the next time the user can replace the bearings on their own. Regards.
The discussion revolves around selecting a front-load slim washing machine under PLN 1,500, focusing on brands like LG, Amica, Bosch, and Electrolux. The user emphasizes the importance of replaceable bearings, which are available in LG, Amica, and some Bosch models. However, there is uncertainty regarding the replaceability of bearings in Bosch machines, with some models having non-removable drums. Electrolux is noted to lack replaceable bearings in their front-load models, while Sharp washing machines do not offer this feature either. Some participants suggest considering the repair of the current washing machine instead of purchasing a new one, as repairs can be cost-effective. The conversation also touches on the availability of information regarding bearing replacement across different brands and models.
