Lark Evolution X4 10.1 - How to hard reset? It cannot be done in the traditional
Mac! 6549 8
  • #1 16775836
    Mac!
    Help: 19
    Rate: 27
    Hello, the tablet was blocked by drawing the wrong pattern.
    I turned off the tablet while holding power. Then, with the tablet turned off, I press "+" and "power" simultaneously and hold until such colored lines appear. Unfortunately, the system continues to load. I tried to hold on longer but it also did not work.
    The tablet is Evolution X4 10.1 (not to be confused with FreeMe).
    On the lark helpline I got the information that they were unable to do it.
  • #2 16776353
    gradek83
    Help: 930
    Rate: 2104
    What chipset do you have this tablet on ... you are able to open it and check ... it's not RK3066 sometimes?
    Did you have USB debugging enabled on your tablet?
    If so, check the command:
    in CMD / DOS type:
    1.cd c: / android / platform-tools
    2. adb reboot recovery
  • #3 16795500
    Mac!
    Help: 19
    Rate: 27
    I cannot open it because it is under warranty. As for USB debugging, it probably wasn't enabled.
    After connecting the usb cable, the tablet is detected but it is not a partition, so I cannot enter the above-mentioned commands ....
  • #4 16795507
    gradek83
    Help: 930
    Rate: 2104
    Take advantage of it.
  • #5 16795508
    Mac!
    Help: 19
    Rate: 27
    I would gladly do it if it were not for an earlier inquiry on the larek helpline where you told me that they are not able to do it, even for a fee.
  • #6 16795569
    gradek83
    Help: 930
    Rate: 2104
    So you are in a dot what kind of company such a service could be said :D
  • #7 16795635
    Zima1978
    1. we keep the volume +
    2. put in the usb plug
    3.Press power and hold or press
    4.We wait for the robot to show up.
    You need to upload new software.
    There are no simple hardresets with RockChip.
    you can try.
    power 2s then press +
    release the power for 1s and press it again without letting go of the +
  • #8 16795650
    gradek83
    Help: 930
    Rate: 2104
    Lark does not officially make it available so he will not upload it on the website, however, as they have it on hand to do it for him, but it is the larka service.
  • #9 16795688
    Zima1978
    You can upload the software after identifying the chip.
    Secondly, you can find software on the net because some people pull out the firmware.
The discussion revolves around the difficulty of performing a hard reset on the Lark Evolution X4 10.1 tablet, which is locked due to multiple incorrect pattern attempts. The user attempted to reset the device by pressing the volume up and power buttons simultaneously, but the tablet continues to load without entering recovery mode. Suggestions include checking if USB debugging was enabled and using ADB commands, but the user cannot access these due to warranty restrictions. Other participants noted that hard resets are complicated with RockChip devices and recommended uploading new software instead. It was mentioned that Lark does not provide official support for this process, and users may need to find firmware online.
