Blow WhiteTab 7.4HD - Hard Reset, Firmware Search, Tablet Stuck on Boot Loop
Noixer 5892 6
  • #1 16569340
    Noixer
    Rate: 13
    Hello! The tablet turns on but keeps spinning and spinning ... How do you do a hard reset on it? I have probably tried all the combinations as they are ... Or maybe someone has firmware for it, because I can't find it.
  • #2 16569376
    piotrek22101
    Help: 695
    Rate: 1417
    Have you tried this combination with the Power + Vol Up keys? You hold for a moment. Unless the button contacts, it will not come in.
  • #3 16569394
    Noixer
    Rate: 13
    I have it connected to a charger, I hold power + volup, the battery disappears, there is a black screen, somewhere after 30 seconds, the inscription Blow appears, and again the battery and that's it. With other combinations similarly.
  • #4 16569411
    piotrek22101
    Help: 695
    Rate: 1417
    Her sister worked last year. Visible firmware has fallen.
  • #5 16569440
    Noixer
    Rate: 13
    Only now where to get a softa to it: /
  • #6 16569748
    nutergsm
    Help: 1034
    Rate: 1663
    Undress and look after marking the disc.
  • #7 16571701
    Noixer
    Rate: 13
    m760 rk3126 v1.04 - does anyone have any firmware for this? I can't find anywhere.
✨ The discussion revolves around troubleshooting a Blow WhiteTab 7.4HD tablet that is stuck in a boot loop. The user seeks assistance for performing a hard reset and finding the appropriate firmware. Various suggestions are provided, including attempting a hard reset using the Power + Volume Up button combination, although the user reports that this does not resolve the issue. There is also a mention of a potential firmware failure, and the user expresses difficulty in locating the necessary firmware for the device, specifically referencing the model m760 rk3126 v1.04.
