Laptop WiFi Card: Permanently Switch from 2.4GHz to 5GHz Band on Dual-Band Router
xrsxrs 10764 1
  • #1 16777988
    xrsxrs
    Rate: 24
    Hello, I have a laptop with a card that supports 5ghz and a router that also supports 5ghz. Is it possible to set somehow in the laptop's network card settings so that it only connects in the 5ghz band each time, because sometimes the laptop connects in the 2.4 band and sometimes in 5. On the router I have to have two bands enabled because some devices other devices at home they only use 2.4ghz, so I won't only give 5ghz on the router rigidly, but I would like the laptop to always connect only in 5ghz. In the settings of the network card somehow I do not see this option to rigidly give 5ghz. Thanks in advance for your help.
  • #2 16777992
    gavron
    Help: 16
    Rate: 52
    Disconnect on a laptop with 2.4 and forget the network, then it will not try :P
