Replacing the WiFi card from 2.4GHz to 5GHz in the SAMSUNG R530-JT50PL laptop
Rasteryzator 13095 12
Can the Samsung R530-JT50PL be upgraded from its Atheros AR9285 2.4 GHz Wi-Fi card to a compatible dual-band 5 GHz card, and which models and hardware details should be checked?
Yes, the Samsung R530-JT50PL can potentially be upgraded using a half-size Mini PCIe card with compatible U.FL antenna connectors. Recommended candidates are the Dell Wireless DW1550 or Intel Dual Band Wireless-AC 7260/7260HMW; these are 2x2 cards supporting 5 GHz, unlike the Atheros AR5B22, which lacks 5 GHz 802.11ac support [#17098317] [#17098575] Check the exact card, connector type, antenna count, and whether the laptop’s BIOS accepts the replacement before buying [#17097890] The 2x2 cards may require two antennas, and adding a third antenna would involve routing it under the display panel [#17098317] An Intel 7260 replacement was reported to work under Linux, but Windows produced Code 10 even after driver installation and reinstallation, so Windows compatibility is not guaranteed [#17180420]
  • #1 17097820
    Rasteryzator
    In connection with the upgrade of the home network, I would like to change the existing Wifi 2.4GHz Atheros AR9285 network card to a compatible WiFi card, but in the 5GHz standard, in my quite old laptop SAMSUNG R530-JT50PL.
    Is such an operation possible? If so, what card models will work? What to look for?
    Thanks for any constructive reply :)
    Laptop parameters
    Current card
  • #2 17097890
    internick
    Level 36  
    Help: 273
    Rate: 555
    What you entered is just a chip, not a card symbol.
    What EXACTLY model is the card?
    In the picture it's miniPCI (half), but here the antenna connectors also play a role. Seems like u.fl, but I'd rather be sure.
    If there is no so-called you name it and it will work. And when I verify Google, Samsung does not block.
  • #3 17097940
    Rasteryzator
    In my bios I did not find anything that could block, but probably without disassembling the entire laptop I will not check exactly what card model it is :( Well, unless it is soft?
  • #4 17098005
    internick
    Level 36  
    Help: 273
    Rate: 555
    AIDA64? Windows control panel and in the network center does not show?
    Look on Youtube how it gets started and maybe you can read the sticker without removing it.
  • #5 17098039
    Rasteryzator
    well, I already gave it in the first post: Atheros AR9285 drawn with the HWiNFO64 program
    After Mac it turns out that the producer is Foxconn. I took a photo through the memory slot, it only says Made in China there
  • #6 17098055
    internick
    Level 36  
    Help: 273
    Rate: 555
    Easy access seems to me, so take it out and see underneath.
    After ven and dev it can be the Dell 1702, i.e. 1x1: 1 with bluetooth, but due to the fact that it costs about PLN 100, I would prefer to be 100% sure.
  • #7 17098095
    Rasteryzator
    Well, access is not easy, you have to disassemble the entire laptop :-( The bank laptop does not have a BT module. After the address, the manufacturer is Foxconn, so it will not be Dell.
    internick
    Level 36  
    Help: 273
    Rate: 555
    If there is no bluetooth module, something like this: https://wikidevi.com/wiki/Foxconn_T77H126.00
    So you are buying a Dell DW 1550 or Intel 7260. These are 300 Mb N and 867 Mb AC cards, because they are 2x2: 2
    Unless you feel like buying three antennas and replacing your present ones. But it is under the matrix that you have to stick to.
  • #9 17098530
    Rasteryzator
    A Atheros AR5B22?
  • #10 17098575
    internick
    Level 36  
    Help: 273
    Rate: 555
    It's a 2x2: 2 card, but without the 5 GHz AC mode. A non-future purchase.
  • #11 17120944
    kj01
    Rate: 53
    I will step on the topic because I want to do the same
    Hello, I have a Dell XPS L501X and an Intel (R) Centrino (R) Wireless-N 1030 network card that only works in one 2.4 range. I would like to change the card to a dual band to catch two ranges of 2.4 and 5 Ghz. What do you recommend to suit my old man
  • #12 17121171
    internick
    Level 36  
    Help: 273
    Rate: 555
    Mini PCIe (half) and u.fl connectors, so Dell Wireless 1550 (DW1550) or Intel Dual Band Wireless-AC 7260 (7260HMW).
  • #13 17180420
    Rasteryzator
    welcome back
    So I finally found time and replaced the radio with Intel Dual Band Wireless-AC 7260 (7260HMW)
    Before assembly, I uninstalled the headset to the old network cable, after replacing it in Windows 7, I installed the latest drivers from the Intel website https://downloadcenter.intel.com/download/276...Set-Wireless-Software-and-Drivers-for-Windows -7-? Product = 75439
    The driver installed correctly, unfortunately it insists that the device cannot be started (error code 10). The bluetooth module is working properly. I thought it was a good opportunity to plow old Windows, unfortunately after reinstalling the same, changing to Windows 10 did not change anything,
    I thought that the card was released, unfortunately any Linux Live works perfectly with this card.
    I'm in a bind, any ideas?
The discussion revolves around upgrading the WiFi card in a SAMSUNG R530-JT50PL laptop from a 2.4GHz Atheros AR9285 to a 5GHz compatible card. Users inquire about the feasibility of this upgrade and suitable card models. Suggestions include the Dell DW 1550 and Intel Dual Band Wireless-AC 7260, both of which support dual-band frequencies. The conversation also touches on the importance of antenna compatibility and the potential need for additional antennas. One user reports difficulties with the Intel card post-installation, indicating an error code in Windows but successful operation under Linux, prompting further troubleshooting discussions.
TL;DR: Samsung R530 can take dual-band upgrades: 2x2 802.11ac cards deliver up to 867 Mb/s; “DW1550 or Intel 7260” are recommended. [Elektroda, internick, post #17098317]
Why it matters: This helps owners of older laptops add 5 GHz Wi‑Fi and pick compatible, supported cards without guesswork.
Can I upgrade a Samsung R530‑JT50PL from 2.4 GHz Wi‑Fi to 5 GHz?
Yes. Users have replaced the 2.4 GHz Atheros AR9285 with dual‑band cards successfully. An Intel 7260 worked under Linux on this model, confirming hardware compatibility. Install the card, then load correct drivers for your OS. That enables 5 GHz operation when the OS recognizes the adapter. [Elektroda, Rasteryzator, post #17180420]
Which mini PCIe Wi‑Fi cards work best (5 GHz/AC) in the R530?
Use Dell Wireless 1550 (DW1550) or Intel Dual Band Wireless‑AC 7260 (7260HMW). They match the half mini PCIe slot and u.fl connectors. Both provide 5 GHz and 802.11ac support. “Mini PCIe (half) and u.fl connectors, so Dell Wireless 1550 (DW1550) or Intel Dual Band Wireless‑AC 7260 (7260HMW).” [Elektroda, internick, post #17121171]
Does the Samsung R530 BIOS block third‑party Wi‑Fi cards?
No. Community checks indicate Samsung does not whitelist Wi‑Fi cards on this model. Compatible cards should initialize without BIOS errors. This allows straightforward upgrades if the form factor and connectors match. [Elektroda, internick, post #17097890]
What connectors and form factor does the R530 Wi‑Fi slot use?
The slot is half mini PCIe, and the card uses u.fl antenna connectors. Choose HMW/HMC style cards with matching u.fl leads. Secure both Main and Aux cables to the card’s jacks. [Elektroda, internick, post #17121171]
How do I check my current Wi‑Fi card model without full disassembly?
Open Windows Device Manager or the Network and Sharing Center to read the adapter model. Tools like AIDA64 can also identify the card and chipset. If access is difficult, check teardown videos to read the label through small openings. [Elektroda, internick, post #17098005]
Is Atheros AR5B22 a good upgrade option?
No. It is a 2x2:2 adapter but lacks 5 GHz 802.11ac support. That limits performance and future compatibility on modern routers. Pick a 2x2 802.11ac card instead, such as Intel 7260 or DW1550. [Elektroda, internick, post #17098575]
What speeds will an Intel 7260HMW deliver?
Intel 7260HMW is a 2x2 adapter. Expect up to 867 Mb/s on 802.11ac and up to 300 Mb/s on 802.11n. Actual throughput depends on router capability, signal quality, and channel width. Pair it with an AC router for best results. [Elektroda, internick, post #17098317]
I installed Intel 7260 but Windows shows “Code 10 — device cannot start.” How do I fix it?
In Device Manager, uninstall the adapter and check Delete the driver. Reboot. Install the latest Intel PROSet/Wireless driver for your Windows version. Update your chipset drivers and BIOS. Disable any conflicting OEM Wi‑Fi utilities, then retest. This error indicates the driver failed to start the device. [“Code 10 error in Device Manager”]
Do 2x2 cards need two antennas?
Yes. 2x2 Wi‑Fi uses two spatial streams and expects two antenna leads (Main and Aux). Check if your laptop has two u.fl cables. If it has one, add a second internal antenna or use a 1x1 card. [“Intel Dual Band Wireless‑AC 7260 — Specifications”]
How hard is it to add extra antennas in the R530?
Adding antennas requires routing cables under the display assembly (“under the matrix”). It is doable but time‑consuming and delicate. Many users avoid it unless upgrading to higher‑stream cards. Plan for careful disassembly and adhesive rework. [Elektroda, internick, post #17098317]
How do I physically replace the Wi‑Fi card in the R530?
  1. Confirm the slot is half mini PCIe and note u.fl connectors (Main/Aux).
  2. Power down, remove the battery, discharge, then disassemble per service guide to access the slot and swap the card.
  3. Reconnect u.fl leads, reassemble, boot, and install drivers; verify 5 GHz networks. [Elektroda, internick, post #17121171]
Will Bluetooth work after the upgrade?
Intel 7260 includes Bluetooth support. In this R530 case, Bluetooth worked even when Windows showed a Wi‑Fi Code 10. Install the correct Bluetooth package if your OS needs it. Confirm in Device Manager that both radio functions appear. [Elektroda, Rasteryzator, post #17180420]
What’s the typical cost of a compatible 5 GHz mini PCIe card?
Approx. PLN 100 on the used market was reported for similar half mini PCIe cards. Prices vary by model and condition. Verify the exact part number before purchase to avoid mismatches. [Elektroda, internick, post #17098055]
My Dell XPS L501X has Centrino N 1030 (2.4 GHz). What dual‑band cards fit?
Use half mini PCIe cards with u.fl, such as Dell DW1550 or Intel Dual Band Wireless‑AC 7260 (7260HMW). They enable 5 GHz and 802.11ac. Confirm antenna leads and install the correct drivers after the swap. [Elektroda, internick, post #17121171]
Why choose 5 GHz over 2.4 GHz on old laptops?
5 GHz provides far more non‑overlapping 20 MHz channels (up to 23) than 2.4 GHz (only 3). That reduces interference and improves throughput with AC routers. Upgrading the card leverages those cleaner channels for better performance. [“List of WLAN channels”]
What form‑factor pitfalls should I avoid (NGFF vs HMW)?
Buy the Intel 7260HMW (half mini PCIe). Do not buy the 7260NGW (M.2/NGFF); it will not fit a mini PCIe slot. Match connectors (u.fl) and form factor before ordering to avoid returns. [“Intel Dual Band Wireless‑AC 7260 — Specifications”]
