Wifi 2.4GHz or 5GHz: Identify Network Standard for Repeater Purchase in Large Building
caton17 47082 4
  • #1 12384797
    caton17
    Rate: 14
    I want to buy a repeater (2.4Ghz) to increase the range of wifi in a large building.
    The problem is that I do not know if I have a 2.4Ghz or 5GHz network. How can you check it?
  • #2 12384856
    mbo
    Help: 2333
    Rate: 845
    What makes this WiFi network?
    Everything will be in the settings of this equipment.
    At 99% 2.4GHz.
  • #3 12384921
    voitek1
    Help: 330
    Rate: 287
    mbo wrote:
    ... at 99% 2.4GHz.
    Upload inSSIDer and if you have a 5GHz card, you will see if the router is transmitting in this frequency. Besides, it's worth reading :!: Eg router manual :idea:
  • #4 12385470
    caton17
    Rate: 14
    I have a router that works in 2 frequency standards, so I will not deduce what it is currently working in.
    inSSIDer unfortunately does not work on XP.
    I installed Network Stumbler, but after detecting my network, it does not say anything whether my network is 2.4 or 5.
    My error, the router only works in the 2.4Ghz standard. So the answer is obvious.
  • #5 12386264
    voitek1
    Help: 330
    Rate: 287
    OKAY.
    besides, download to XP SP3 (if you don't have it yet ...)
