Samsung i9505 Nand Erase All in Odin: Data Recovery & Fix Logo Hanging Issues
kamil9912 2535 4
  • #1 16791460
    kamil9912
    Rate: 21
    Hello, as in the topic of the phone softened by odin, this function was selected, faill popped up, the phone hangs on the samsung logo all the time, I softened with a four-file and crashes an error in odin. The question is, is it possible to restore data after such an operation? Question 2 is it possible to put the disc in any way.
  • #2 16791790
    nutergsm
    Help: 1034
    Rate: 1666
    Try Smart Switch or Kies. You cannot restore the data.
  • #3 16791801
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    The basic question is why did you upload the new soft?
  • #4 16791884
    kamil9912
    Rate: 21
    The phone kept cutting and therefore, the kies does not detect the phone, the other program also does it, will the data be recovered with some box, is there any chance?
  • #5 16794168
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    So the probability is high that the memory is damaged.
    You can recover everything as long as you have the right equipment. In your case, the service remains.
