Samsung Galaxy S7 Edge Firmware Upload: Odin v.3.10 Freezing at 90-95%
gabik001 4737 3
  • Odin flash hangs at 90–95% on S7 Edge
    #1 16752023
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    I am not a GSM specialist, sometimes I pick something and I have a problem to solve. The phone is a friend she got from a friend who used it for some time. A friend bought a new S8 and gave this one to my friend instead of throwing it away. Only the SIM drawer was missing, but that's not a problem. A friend wanted to do a reset, but of course after the reset, she gave her google account details (which the friend does not know) to a friend as she used it before. My friend went abroad for a longer time and there is no way around it. She asked me if there was anything to be done about it. I wanted to install Andka from scratch. I downloaded Odin v.3.10 and the stock firmware for this model. I searched the internet what and how and everything I do as in the descriptions. The program loads the files as it should into the phone and after loading the file with the system when loading the next file (somewhere around 90-95%) Odin hangs and asks to close the program. The drivers are installed correctly, I tried on W10 and on W7. In both cases, it ends with Odin's indignation.
    The only thing I don't know is if USB debugging is enabled on the phone. How can I not check it. I suspect there may be a problem here. Is there any way to enable debugging when the system is not fully booted, or some other way to install Android to keep this phone working?
    I will add that after incomplete copying of files, it tries to update, but it ends up with "no command" Android. Then, of course, you can run it either in the download mode or in the recovery mode.
    Thanks in advance for your valuable advice.
    arti123
    Help: 377
    Rate: 96
    Try this version of Odin. https://dl.sammobile.com/Odin3-v3.12.7.zip, download the latest version of the software (the latest version for Poland is G935FXXS1DQHI - CSC G935FXEO1DQGQ). The problem with the google account will not disappear after uploading the firmware, so you will have to get tired or take it to the site.
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Try the SmartSwitch program which will download the appropriate soft itself.
    As for the google account, a friend has already written that there will be no service without the website.
    Debugging to upload software is not needed.
  • #4 16754050
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    Thanks guys for the hint.
    This is the version of Tmobile US and I downloaded the soft one for it. I tried with another Odin, only on a different cable it went (shorter than a portable drive). But the problem with the account remains, so I will not torture him and I will advise my neighbor to wait for the friend to come back or go to the website. At this point, my mission is complete. I do what I can and I am not an eagle from GSM ...
    I consider the topic exhausted.
    Thank you
