Seat Ibiza 1.2 2006 - Oil Lamp Blinking, Squealing, and Stopping Changes: Causes & Solutions
qqwwee11 45504 7
  • #1 16792342
    qqwwee11
    Rate: 19
    Hello .
    Recently I rode and the oil lamp started to blink and disappeared and every now and then appeared I arrived home and thought that little oil but the oil was exchanged this month but instinctively I poured in and the same blinked and ceased and looked at the bayonet and shed oil this colleague I sucked as much as I need to make the level good and I was happy because I traveled somewhere 25 km and nothing lit up when I arrived home and I was apologized to the mud and gassed the car for one to 4 thousand turns the light again started to blink and squeak I drove into the garage, I extinguished the car, fired again the control simply disappeared I opened the mask I irritated the oil level and is okay later I gassed the engine at ease and the control did not ignite and I bet that tomorrow as somewhere I will go again squeak strange thing really. My car is Seat Ibiza 1.2 2006. I am asking for some reasonable advice because I do not want to throw away money at the mechanic for free to exchange something and then it happened :D . greetings
  • #2 16792488
    marek216
    Help: 1076
    Rate: 923
    I bet on the imminent death of an oil pump. With luck, you only have a problem with the oil sensor, but I would not be an optimist. Instead of foreseeing, visit a mechanic before you break the engine.
  • #3 16792563
    qqwwee11
    Rate: 19
    Well, unfortunately, it would be weak
    Added after 7 [minutes]:
    but what I noticed is that it turned on every second minute on average and today I went a long time and only at the end ...
  • #4 16792608
    Przemo9826
    Help: 374
    Rate: 2498
    After all, you have to measure the oil pressure ... Without this a strict prohibition to start the engine, and you are to head off and ride. You probably destroyed the engine.
  • #5 16792620
    qqwwee11
    Rate: 19
    so I destroyed the engine and to do the measurement you have to start the engine ;)
  • #6 16792635
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4171
    There is one trifle, cars from the vag group, the oil pressure measurement are only done for 2 thousand rpm, i.e. the engine without oil is fired and kept at 2 o'clock, it will seize without igniting the oil pressure gauge.
  • #7 16792653
    qqwwee11
    Rate: 19
    Well, there is nothing else to do but go to the pressure measurement to the mechanic as soon as possible
    I did not know just what the effects might be but I have a quiet hope that it is not a pump :D
  • #8 16798407
    qqwwee11
    Rate: 19
    The subject to close the cause of this fault was the oil pressure sensor from which the oil leaked. If someone has a problem with this and will read this post, the control light went on after driving about 20 km and it ignited and disappeared all the time. greetings
✨ The discussion revolves around a 2006 Seat Ibiza 1.2 experiencing intermittent oil lamp blinking, squealing noises, and engine stopping. Initial troubleshooting included checking the oil level, which was deemed adequate after a recent oil change. Responses suggest potential causes such as a failing oil pump or oil pressure sensor issues. It is advised to measure oil pressure before further engine operation to prevent damage. Ultimately, the problem was identified as a leaking oil pressure sensor, which caused the warning light to activate after driving approximately 20 km.
