Fiat Punto 1.2 8v IAW59F.E4 ECU - EEPROM 95080 Read & Immo/Virgin Removal with Galletto Tool
bialo_czarny1 15477 5
  • #1 16823533
    bialo_czarny1
    Hello. I need to exchange ecu in punto 1.2 8v. It has the iaw59f.e4 driver. And I have to remove immo or virgin. I know there are two ways to either read the eeprom 95080 or boot mode. I have a galleto and is it enough to connect according to the diagram?
    How to read such an eeprom? Solder the cables to the boxes shown in the picture?
    Thanks in advance for your help
    • Fiat Punto 1.2 8v IAW59F.E4 ECU - EEPROM 95080 Read & Immo/Virgin Removal with Galletto Tool ECU IAW_MARELLI_59F_FIAT.jpg (97.96 KB) You must be logged in to download this attachment.
    • Fiat Punto 1.2 8v IAW59F.E4 ECU - EEPROM 95080 Read & Immo/Virgin Removal with Galletto Tool pobrany plik.jpg (12.47 KB) You must be logged in to download this attachment.
  • #2 16824651
    mako110
    Help: 37
    Rate: 264
    Jelly will embrace this driver as described ...
  • #3 16825625
    CAR pass
    Help: 41
    Rate: 239
    Why are you replacing the ECU?
    I ask out of curiosity because I remember I had several cases of lack of communication and it wasn't a computer
  • #4 16826561
    mar.wo
    Help: 10
    Rate: 84
    I / O Terminal will do in 6 seconds, look for a colleague nearby.
  • #5 16830179
    bialo_czarny1
    I have to replace because he is beaten. The computer shows a misfire
  • #6 16830208
    adam7009
    Help: 656
    Rate: 1635
    buy clean unless you already have.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
