How to Connect Lexman Two-Button Switch from Leroy Merlin for Dual Lamp Types: Troubleshooting
Canadian82 51786 11
How do I wire a Lexman two-button switch so both lamp circuits work independently from the three wires in my installation?
This switch is a double staircase switch, so to use it as a normal two-circuit switch you must make a jumper between L1 and L2 and connect the phase wire there; the two lamp wires then go to X1 and X4 or X2 and X3 [#16825876] Another suggested wiring for the pictured terminals is to put the blue wire on the upper left clamp, leave the black wire in place, connect the brown wire to the upper middle clamp, and add a bridge to the lower middle clamp [#16825896] If one button still affects both lamps, the phase wire is likely in the wrong terminal and needs to be moved [#18330095]
  • #1 16825839
    Canadian82
    Rate: 18
    I warmly welcome
    I have such a switch purchased in the Leroy Merlin store and three cables in the installation on which I have two types of lamps. And now my question after just like in the picture, only one type of lamp is lit, but the other does not work at all. What I'm doing wrong
    I am asking for help and thank you in advance for it How to Connect Lexman Two-Button Switch from Leroy Merlin for Dual Lamp Types: Troubleshooting
  • #2 16825851
    krzysiek7
    Moderator of Electricians group
    Help: 678
    Rate: 1955
    How are these two types, can you explain it somehow?
    What power do you have on the vein?
  • #3 16825859
    Canadian82
    Rate: 18
    I think the power is on a brown vein. Two keys (one key activates one lamp, the second one runs the other lamp, but only one button works, switching on the light in one lamp the other button does not work. It's so chaotic as much as the knowledge allows ...
  • #4 16825870
    krzysiek7
    Help: 678
    Rate: 1955
    Have you already had the switch installed so far and now replace it?
  • #5 16825874
    Canadian82
    Rate: 18
    No switch is mounted new, but when I plug the old switch, on which there are only three terminals, it works ... and here nothing: /
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    Eh the hero in his own home :)
    Do you see the wiring diagram on the sticker?
    This is a double stair switch. Wanting to use it as so-called you need to make a jumper between L1 and L2 and additionally connect the phase wire there. You connect the lamp outlets under X1 and X4 or X2 and X3.
  • #7 16825891
    Canadian82
    Rate: 18
    thanks for the quick answer tomorrow I will come to the apartment and check
    krzysiek7
    Help: 678
    Rate: 1955
    You had a candlestick connector, and you bought a double staircase, but you can connect it. Attach the blue wire to the upper clamp on the left side, leave the black one in place, connect the brown wire to the upper middle clamp and make a bridge to the bottom center clamp with a piece of wire.
  • #9 16825909
    Canadian82
    Rate: 18
    thank you again
  • #10 16825955
    mawerix123
    Help: 482
    Rate: 951
    krzysiek7 wrote:
    you leave the black in its place
    How do you know that brown is power :?:
  • #11 18329433
    ekwador15
    I have the same cables as the author of this thread and such a double light switch as in the picture.
    And where L is in the middle, of course I connected the phase, on the left I connected the blue cable and on the right black. And the effect is that one button lights a chandelier, the second button lights from the suspended ceiling, but the first button from the zerandol if it is turned off, it also extinguishes the lights from the suspended ceiling, although the other button is still on. how to bite it so that each button turns on the light independently.
  • #12 18330095
    mawerix123
    Help: 482
    Rate: 951
    Plug the power cord into place, you have misplaced the phase wire.
The discussion revolves around troubleshooting the Lexman Two-Button Switch purchased from Leroy Merlin, which is intended to control two different types of lamps. The user reports that only one lamp is functioning, while the other remains off. Responses suggest checking the wiring connections, specifically ensuring that the phase wire is correctly connected and that a jumper is made between L1 and L2. Additional advice includes connecting the blue wire to the upper left clamp, the brown wire to the upper middle clamp, and bridging the bottom center clamp with a piece of wire. The conversation highlights the importance of proper wiring to achieve independent control of each lamp.
TL;DR: The Lexman two-button is a 2-circuit switch; "This is a double stair switch." Bridge the two commons and put live on the bridge for independent control. 2-gang = 2 outputs. [Elektroda, xury, post #16825876]
Why it matters: It fixes the “one button kills the other light” issue and prevents miswiring damage in minutes.
How do I wire the Lexman two-button switch for two independent lights?
Bridge L1 to L2 with a short wire. Land the incoming phase on that bridged common. Connect the two lamp return wires to a matched pair of outputs, either X1 and X4 or X2 and X3. This gives true independent control. "This is a double stair switch." [Elektroda, xury, post #16825876]
Only one button works—what did I do wrong?
You likely didn’t bridge the two commons (L1 and L2) or you placed the phase on an output. Add a jumper between L1 and L2, then move the phase to that bridged common. Put lamp leads on a matched output pair (X1/X4 or X2/X3). [Elektroda, xury, post #16825876]
One button turns off the other light—why does that happen?
That symptom indicates the phase wire sits on the wrong terminal. Move the phase to the common terminal (the one you bridge) so each rocker feeds its own output. After correcting, each light stays on independently. "Plug the power cord into place, you have misplaced the phase wire." [Elektroda, mawerix123, post #18330095]
Where exactly should the live (phase) conductor go on this switch?
Place the phase on the middle common terminal, then add a short bridge to the second common. This mimics a two-circuit feed and lets both rockers share one live. The lamp returns stay on their respective outputs. [Elektroda, krzysiek7, post #16825896]
Can I trust wire colors like brown, black, and blue to identify live and switched?
No. Do not assume brown is live. Identify the live with proper testing before wiring. Misidentifying conductors leads to cross-switching or nonfunctional circuits. Color hints can mislead; verification prevents faults and nuisance tripping. [Elektroda, mawerix123, post #16825955]
My old three-terminal switch worked, but the new two-button doesn’t—what changed?
Your old unit likely tied the commons internally. The new double-stair switch expects two separate commons. Add a small jumper between L1 and L2, put the phase on that bridge, and move the lamp leads to the correct outputs. [Elektroda, xury, post #16825876]
Which output terminals should feed the two lamps?
Use a matched pair: X1 and X4 or X2 and X3. Keep both lamp returns on the same side’s designated outputs to avoid cross-coupling. This layout matches the internal rocker routing for predictable switching. [Elektroda, xury, post #16825876]
Quick 3-step: how do I fix the wiring so both buttons work independently?
  1. Move the incoming phase to the middle common and add a jumper to the second common.
  2. Put lamp A’s return on X1 (or X2).
  3. Put lamp B’s return on the paired output X4 (or X3) to match step 2. [Elektroda, krzysiek7, post #16825896]
I have three wires in the box; can this still control two lamp groups?
Yes. One conductor supplies phase to both rockers via a bridge, and the other two are switched returns to each lamp group. This thread’s case used three conductors exactly in that way. [Elektroda, Canadian82, post #16825839]
What common mistake should I avoid when swapping to this Lexman switch?
Avoid placing the phase on an output terminal. That causes interdependence between rockers and odd behavior. Always land phase on the bridged common, then connect lamp returns to the paired outputs. Fixing this resolves the failure case instantly. [Elektroda, mawerix123, post #18330095]
Is this Lexman two-button suitable to replace a candlestick (dual-circuit) switch?
Yes. It’s a double-stair model, but it can act as a dual-circuit switch when you bridge the commons and place the phase there. Then route each lamp return to its paired output. [Elektroda, krzysiek7, post #16825896]
Why did only one lamp type light after my first attempt?
The second lamp’s return likely sat on the wrong terminal, or the commons were not bridged. Add the L1–L2 jumper, confirm phase on the bridge, and relocate the second lamp lead to the correct paired output. [Elektroda, xury, post #16825876]
