Unlock & Remove Simlock on Nokia 515 (RM-953) with Orange: HASH Reading Issues, DKU-2 Cable & More
Seroz 5928 5
  • Need a compatible Nokia PC Suite connection mode
    #1 16846068
    Seroz
    Rate: 26
    I have Nokia 515 with an unlock on Orange wanting to remove it with a bruteforce (for a fee on AlleDrogo at least PLN 20 is a good price) I had a problem with reading HASHA (here is a request for help)
    Following the instructions at the auction, step by step, unfortunately I can not read HASH and because of the error in connecting the phone with the PC Suite, he sees it non-stop as a non-compatible device (although I have a DKU-2 cable from Nokia)
    And my question sounds like how else can I read it (HASH) or maybe someone has an idea what I'm doing wrong ??? After 2 hours on Google, I softened - I tried the "Best" program and similar programs, but it did nothing / "rudders" to the cable I installed / computer sees the phone - starts it from the machine / Tel does not have the PC Suite option when connecting the cable
    Or maybe someone even knows to remove SIMLOCK from this phone ??? Somehow different ???
    Thanks in advance for any help and advice :)
    yulu
    Help: 234
    Rate: 25
    You will not do.
    20-character code, not countable. Buy operator code
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Orange codes are easily available at prices around PLN 70.
  • #4 16846517
    Seroz
    Rate: 26
    So on AlleDrogo for 20 PLN is a fake even though this model is listed .....
    You can ask for some information to do it and maybe a little cheaper like the 70 zlotys
    On the net goes to find it cheaper but is it worth the risk ???
    Well, is Hasha myself reading? Is this model unique ??
  • #5 16846536
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Can you read comprehension? A colleague has already written that the hash cannot be read. Only after IMEI.
  • #6 16848798
    Seroz
    Rate: 26
    Yes, I can read comprehension
    yulu wrote:
    You will not do.
    This did not explain much in the subject
    This is a general answer so I took it for it
    Now you have written more so I am 100% sure thanks to you that I will not read HASH myself and it was possible right away
    Thank you for your help
