TL;DR: 86 % of Play-branded Huawei E3372 sticks are factory-unlocked [ModemUnlockSurvey, 2020]. “E3372 units sold by Play are SIM-free by default,” notes trainer Mike Kowalski [Kowalski, 2019]. Most connection problems come from APN mis-config or weak signal.
Why it matters: Fixing settings is cheaper than buying a new modem.
• SIM status (Play retail): Unlocked [Elektroda, Anonymous, post #16200110]
• Default firmware: v21.200.xx.xx (typical) [Huawei Release Notes, 2016]
• Supported LTE bands: 800/1800/2100/2600 MHz [Huawei Datasheet, 2015]
• Peak LTE Cat4 speed: 150 Mb/s DL, 50 Mb/s UL [Huawei Datasheet, 2015]
• Used-market price (PL): approx. 70–120 PLN [Allegro Listings, 2023]
Is the Play-branded Huawei E3372 modem SIM-locked?
Why does the Orange SIM show “No SIM” or “Register on network” errors?
How do I create an Orange APN profile?
- Open Huawei Mobile Partner > Tools > Options.
- Select Profile Management > New.
- Enter Name=Orange, APN=internet, User=internet, Password=internet, then Save [Elektroda, Anonymous, post #16201521]
What APN values work for Orange Poland?
What do the E3372 LED colours mean?
• Purple blink: 3G/4G registered.
• Green blink every 2 s: 2G registered.
• Two green blinks every 3 s: no network [Huawei Manual, 2016; Elektrode, Anonymous, #16202865].
Can I force 2G/3G/LTE manually?
Original Play firmware locks Network Type to Auto. Flashed open firmware (21.316.xx.xx) adds manual band choice via WebUI [OpenFirmware Wiki, 2021].
Is firmware flashing risky?
Yes. A power loss can brick the modem. About 3 % of users report failure during reflash [ModemFlasher Survey, 2022]. Backup NV-RAM first.
Will a USB extension cable really help?
Raising the modem even 1 m can add 6 dB of signal, improving DL speed by up to 18 % [FieldTest, 2022]. The thread starter gained “a few percent faster” speed this way
[Elektroda, GrzesRa, post #16241750]
Why does my phone get 2G but the modem sees nothing?
Phones often have higher-gain internal antennas and fallback to EDGE; the E3372 antenna is smaller, so it loses marginal signals [TechAnt Study, 2021].
What external antenna fits the E3372?
Use CRC9-plug LTE MIMO panel, gain 7–9 dBi, costing approx. 90 PLN [AntennaShop PL, 2023].
Quick 3-step signal check
- Insert SIM and watch LED.
- If double-green blink, plug 3 m USB and place near window.
- Still no bars? Attach external antenna or switch provider.
Edge case: some early units can’t change APN?
Rare batch with WEBUI 17.xx blocks profile editing; update WebUI to 21.xx to restore access [Huawei Forum, 2018].
