Lenovo Vibe K5 - Ekran Not Responding, Notification LED On, Screen Won't Turn On: Solutions?
Precelek183 4659 6
  • #1 16846117
    Precelek183
    After finishing the conversation on the Lenovo Vibe K5 phone, I closed the screen and turned off, after about 5 minutes, when I wanted to turn on the phone, nothing happened, the notification LED is on, I took out the batteries. After all the attempts it did not work, anyone from the forum knows what can be about? :|
  • #2 16846355
    helterskelter33
    Help: 22
    Rate: 57
    The software has spilled. Give the warranty as you have.
  • #3 16846392
    Precelek183
    Nwm or software, because messages on the masender come and when someone calls too, only the screen is black
  • #4 16846803
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    It could fall lcd.
  • #6 16847397
    Precelek183
    On Friday morning at 7:42 I made a call, everything was ok, I blanked the screen after 2 minutes and turned on and nothing, only the notification diode and the whole phone works, generally, even touch, I tried turning on and off and nothing :P
  • #7 16847505
    helterskelter33
    Help: 22
    Rate: 57
    So follow the hard reset instructions from the link I gave in the post above. It seems that an application is causing these problems. A hard reset should help.
The Lenovo Vibe K5 user reported that after turning off the phone, it failed to turn back on, with only the notification LED active. Responses suggested potential issues such as software failure or LCD damage. A hard reset was recommended as a possible solution, with instructions provided via a link. The user confirmed that the phone still receives calls and messages, indicating that the device is operational despite the screen being unresponsive.
