Lenovo K5 6020a40: Persistent Issues After Unsuccessful CM Installation and Reset Attempts
geroj69 6729 5
  • #1 17535360
    geroj69
    Hello, not long ago I became the owner of the Lenovo K5. Unfortunately, it turned out that someone tried to install CM on this phone, but you can see it to no avail. I tried hard reset and factory reset, but unfortunately it can't be done, after factory reset the phone restarts and stays on the lenovo log. and so on with an hour. Google tutorials do not give advice.
    greetings :D
  • #2 17535385
    dr.master
    Help: 518
    Rate: 927
    And what movements did your colleague make to activate this phone?
    You have to manually upload new software for him.
  • #3 17535511
    geroj69
    I tried this solution, but unfortunately I cannot turn on the phone in such a way as to upload it. The volume up and down buttons with the on button pressed do not have the effect of uploading the stock. Is there any way to completely remove the software and upload everything one by one?
  • #4 17535535
    dr.master
    Help: 518
    Rate: 927
    Just the volume - (lower) button and the power key try it.
  • #5 17535579
    geroj69
    Then the Lenovo logo pops up and at the bottom it says that pressing the power button and holding it will restart the phone. Not in Polish, of course; I also tried that program in this mode, but to no avail
  • #6 17535584
    dr.master
    Help: 518
    Rate: 927
    Since you are not able to enter download mode, i.e. the equipment must be delivered to a specialist.
