[Solved] Affordable External Speakers for Sony KD-55XE9005 TV: Sony Soundbar 5.1 HT-RT3 & HT-RT4 Comparison
Staszicu 5385 12
What affordable external speakers or soundbar should I buy for a Sony KD-55XE9005 TV to improve movie dialogue and handle 5.1/7.1 sound?
A budget Sony 5.1 soundbar set such as the HT-RT4/HT-RT3 is a reasonable choice for your Sony TV, with the HT-RT4 described as quite good and having better bass than comparable Samsung models if you can live with the rear-speaker cables [#16855765] One reply also said that a multi-speaker soundbar is the right kind of upgrade for getting proper TV surround sound and recommended testing the set in a store before buying [#16853618] Do not choose the HT-CT790 if you need DTS 5.1, because it was described as only a 2.1 system and not suitable for DTS 5.1 playback [#16855816] If the dialogue is still too quiet after installation, check the TV/soundbar settings and try both HDMI ARC and optical output, since optical was said not to degrade the signal [#16870268][#16870861][#18285318]
  • #1 16851170
    Staszicu
    Level 4  
    Rate: 9
    This week I bought the Sony KD-55XE9005 equipment, but the built-in sound offered is not satisfactory (while watching the 5.1 / 7.1 video materials, the voiceover is too quiet and the dynamic scenes are too loud).
    I would like to purchase external speakers.
    I did not take into account the purchase of speakers when buying a TV, so my budget is not high (maximum PLN 1000-1200).
    Could you please advise me what equipment (maybe a soundbar?) I could buy at this price that would solve my problem with watching movies with 5.1 / 7.1 sound?
    I found two Sony Soundbar 5.1 sets:
    https://mediamarkt.pl/rtv-i-telewizory/soundbar-sony-ht-rt3
    https://mediamarkt.pl/rtv-i-telewizory/soundbar-sony-ht-rt4
    Is it a good choice and is it worth getting into soundbars? If so, what equipment would you recommend?
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    Both soundbars will be a good choice to complement your TV with a set for a better listening experience because the soundbar will give you great sound from the front speakers, the subwoofer will give you the depth of the explosions and the rear speakers will put you in the center of the action.
  • HT-RT3 subwoofer fan noise and pricing question
    #3 16853505
    Staszicu
    Level 4  
    Rate: 9
    Before buying, I got acquainted with the reviews of the above-mentioned Sony Soundbar HT-RT3 equipment.
    On one of the pages, I found such a review (although it concerns the ST3 model, from what I can see, it offers 4.1 sound):
    [...] I had to do it with the remote control in my hand. Why? The dialogues could be heard quite poorly, which made the sound much louder. Only until somebody else did not whine the engine, no music started playing in the background, etc. Then you feel the most uneven sound distribution. Very quiet to unacceptably too loud. [...]
    Source: https://jotem.in/soundbar-sony-ht-st3-test-opinie-recenzja/
    and:
    Today I picked up the Sony HT-RT3 5.1 soundbar, everything is nice, but the subwoofer makes some additional sound like a fan, such a squeaking. When there is a voice from a TV program or music, it goes on all the time when a break in the sound is like something turned off.
    Okay I already know, the fan is in the subwoofer. I sent the equipment back to the store, I do not recommend it.
    - So after buying the HT-RT3 soundbar, there may still be a problem with the "silent reader"?
    - Can the operation of the fan in this model be so onerous?
    By the way. While browsing other soundbars, I came across 2.1 models that cost PLN 1,500 and were sometimes more expensive than 5.1 soundbars.
    Shouldn't it be the other way around? :D I don't think I quite understand it.
    Soundbar 5.1 needed for clearer voiceover audio
    #4 16853618
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    As with cars, one costs 50,000, another 200,000, the same is the wide range of cable prices for loudspeakers from PLN 1 / m.
    https://audio.com.pl/testy/stereo/kable-glosnikowe/995-audioquest-mont-blanc
    The lack of the correct voice level of the voiceover is caused by the lack of the appropriate number of speakers in the TV, which has only two instead of 6. When you turn on DTS on TV, the voice of the voiceover has nowhere to reach the listener, so it is heard from a distance, attaching a soundbar will allow you to fully use the sound from the TV and the voiceover will be audible for sure. Soundbars of interest are a set of multiple speakers that provide 5.1 sound, not just stereo. I suggest going to the store and asking the staff to allow you to test the listening session.
    jotem.in
    Thanks for the quote board :)
    When it comes to soundbars, I tested a lot of Sony and Samsung equipment. In these comparisons, the Sony came out better, which is cheaper to buy and has a much better bass.
    You asked about the RT4, I also tested this equipment and it is quite good as long as you do not mind the cables / sony-ht-rt4-soundbar-additional-speakers-tyl-review /). Be sure to take a look at the HT-CT790 because it is a device that can also be recommended.
    Regards,
    Jacob
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    I do not recommend the HT-CT790 soundbar because while the sound quality is at a decent level, unfortunately it is not suitable for DTS 5.1 sound reproduction because it has speakers for the 2.1 system, i.e. stereo with bass enhancement. The only function it is good for is making noise, not making sound as a home theater, and the author of the post is about using the capabilities of the TV and DTS 5.1 quality sound.
  • #7 16859373
    Staszicu
    Level 4  
    Rate: 9
    I liked the RT4, but I do not know if there will be a place for them in the room, which is why I was interested in the RT3 product (due to the possibility of placing it on the wall) and I was practically ready to buy this equipment, but I was scared off by the opinions about the noise fan. I visited Media Markt in order to "see" the equipment, but the noise that accompanies this place made it impossible to verify whether the fan's operation is really such a nuisance.
    I would like to make a purchase tomorrow (I would like to charge the equipment).
    So finally:
    - Do you think HT-RT3 equipment is a good choice?
    - Is the HT-RT4 model better than HT-RT3 in terms of build quality, or is it the same "shelf"? (RT3 = PLN 999, RT4 = PLN 1300)
    - Maybe someone from your RT3 had and could express his opinion on the fan?
    -edit
    I purchased RT3 today.
    At home, I connected the equipment with an HDMI cable, the TV itself detected the connected speakers and properly activated the option on the TV, the connection itself was very easy (everything was perfectly color-coded).
    I turned on the 5.1 video material for the test, unfortunately, the voiceover, as it was quiet, is true for all my productions.
    Hmm .. I must admit that I expected a solution to the problem with the teacher, but perhaps for the price of 1000 PLN you cannot buy equipment that will guarantee a pleasant reception of the film and I am a bit disappointed. I know that the equipment is not very high-end, but I thought it would be good for the voiceover.
    As for the fan, it is virtually undetectable, in my opinion users have been exaggerating with its loud work.
    Well, I have 3 days to return, I will test it, at most the equipment will return to the store, I am already a bit tired of this fight with the sound.
  • #8 16869883
    Staszicu
    Level 4  
    Rate: 9
    The problem with the voiceover lies with the soundbar - it does not support DTS. It is a pity that I have not read it before. Well, I blended in a bit with this soundbar.
    Is there any way for my equipment to cope with DTS sound? (elimination of the silent reader).
    Heard you can buy some external decoder.
    KOCUREK1970
    Help: 3866
    Rate: 5499
    You have 14 days to return without giving any reason (individual customer).
    Grajbelka also has an optical port - have you tried through such a connection?
    Perhaps you also need to calibrate them first, set these speakers in the equipment itself ...
  • Optical connection may avoid HDMI ARC issues
    #10 16870813
    Staszicu
    Level 4  
    Rate: 9
    The equipment was purchased on invoice.
    I have not tried through the optical cable. While connecting the sound system, both in the manual and on the TV screen, a message was displayed to connect the equipment via HDMI (exactly HDMI ARC), which I did.
    Tomorrow I will check and connect the sound system via the optical cable, but I have read (maybe wrongly) that the optical cable will make the sound much worse. How is it with this?
    Apart from the limitation which I wrote about in the case of SPDIF (nothing will be except STEREO PCM 192 k / 24 bit, AC3 48K 5.1 lossy, DTS 48K 5.1 lossy) SPDIF has the advantage of an "non-electric" connection ... there is no mass transfer of garbage, there is no possibility of ground loops at this point.
    Optical cable should not degrade digital audio
    #11 16870861
    KOCUREK1970
    Help: 3866
    Rate: 5499
    Any purchase for a retailer (private person) - you have 14 days from receiving the parcel to return.
    Staszicu wrote:
    I read (maybe wrongly) that the sound will be much worse through the optical cable. How is it with this?
    How can it be worse if it is sent in its original form and with fiber that does not introduce any disturbances?
    It may only be necessary to run this port on tv and what data is to be sent through it.
    I myself have a Samsung music bar connected to a computer with an optical cable - it plays flawlessly.
  • #12 16872480
    Staszicu
    Level 4  
    Rate: 9
    I purchased an optical cable today.
    It seems to me that the rear speakers are a bit louder (at least you can hear something from them, although it seems to me that they just reproduce the sound no matter which direction it comes from, but maybe I'm already oversensitive). The lector, unfortunately, as he was quiet, he remained so, the TV also detects the audio system and outputs sound from both the speakers on the TV and from the soundbar (you need to mute the TV manually), should it be?
  • #13 18285318
    Staszicu
    Level 4  
    Rate: 9
    The issue was resolved after reconfiguring the TV and speaker settings by trial and error.
The discussion revolves around the user's dissatisfaction with the built-in sound of the Sony KD-55XE9005 TV, particularly when watching 5.1/7.1 audio content. The user seeks affordable external speakers, specifically considering the Sony Soundbar models HT-RT3 and HT-RT4, with a budget of PLN 1000-1200. Responses highlight that both soundbars can enhance the audio experience, providing better sound quality and depth. Concerns about the HT-RT3's fan noise and its ability to handle DTS sound were raised, with some users recommending testing the soundbars in-store. The user ultimately purchased the HT-RT3 but later encountered issues with voice clarity and sound configuration, which were resolved through adjustments to the TV and speaker settings.
TL;DR: Prices vary wildly (speaker cables from PLN 1 per meter), and “go to the store and ask for a listening test.” [Elektroda, nomudrek, post #16853618]
Why it matters: This FAQ helps Sony KD-55XE9005 owners fix quiet dialogue and choose between Sony HT-RT3 and HT-RT4 on a tight budget.
Which is better for my Sony KD-55XE9005: HT-RT3 or HT-RT4?
HT-RT4 earns a thumbs‑up for sound if you accept wired rears. An experienced tester wrote Sony sets “came out better” with stronger bass. If tidy cabling matters or space is tight, HT-RT3 is smaller but has notable format limits. Try in‑store listening before buying. [Elektroda, jotem.in, post #16855765]
Why are movie dialogues so quiet on my TV with 5.1/7.1 content?
Your TV has two speakers, not a full 5.1 array. Center‑channel dialogue in multichannel mixes lacks a proper speaker path, so voices sound distant while effects jump out. Adding a multichannel bar helps, but only if it supports your audio formats. “Attach a soundbar and test in store.” [Elektroda, nomudrek, post #16853618]
Does the Sony HT-RT3 support DTS, and what happens if I play DTS?
HT-RT3 does not decode DTS. When fed DTS, you get very low voiceover/dialogue or mismapped channels. The thread author traced quiet dialogue to this exact limitation and sought ways around it. Reconfigure source output to avoid DTS or consider a model with DTS. [Elektroda, Staszicu, post #16869883]
Is the HT-RT3 subwoofer fan noisy in a living room?
One owner reported the sub’s fan as “virtually undetectable” at home. Earlier online comments worried about whine, but their in‑room result was calm and unobtrusive. Always test in your space, as placement and distance change perception. [Elektroda, Staszicu, post #16859373]
Are some 2.1 soundbars pricier than 5.1—why?
Price tracks performance, features, and build, not only channel count. As one reply put it, audio pricing spans a wide spectrum—like cars—and even cables run from PLN 1 per meter. Judge by sound quality and needs, not just 2.1 vs 5.1. [Elektroda, nomudrek, post #16853618]
Is optical (SPDIF) worse than HDMI ARC for sound quality?
Optical is digital and immune to electrical noise. A member reports flawless playback via optical and notes you may need to enable the port and choose what data it sends. Format limits apply, but optical itself doesn’t degrade bits. [Elektroda, KOCUREK1970, post #16870861]
What are SPDIF/optical limitations I should know about?
SPDIF typically carries PCM stereo or lossy 5.1 (AC3/DTS at 48 kHz). It won’t pass advanced codecs beyond that. This is an edge case when your files are DTS‑HD/TrueHD; they will be downmixed or not decoded as expected. [Elektroda, Staszicu, post #16870813]
How do I stop sound coming from both the TV and the soundbar?
This occurs when the TV continues to use its speakers while also outputting audio. In the thread, the TV and bar both played until settings were adjusted. Open audio settings and switch the TV speakers off or set Audio System priority. [Elektroda, Staszicu, post #16872480]
How can I fix very quiet dialogue on HT-RT3 with my Sony TV?
The issue was resolved by reconfiguring TV and speaker settings through trial and error. Change audio output format away from unsupported modes, confirm the bar as the active audio system, and retest with known material. Keep adjusting until dialogue normalizes. [Elektroda, Staszicu, post #18285318]
Can I add an external DTS decoder to make HT-RT3 work with DTS?
The thread raised this idea but did not confirm a hardware fix. Instead, the final resolution came from TV/soundbar setting changes, not extra boxes. Avoid DTS output or pick hardware with native DTS support. [Elektroda, Staszicu, post #18285318]
Is HT-CT790 a good alternative here?
One responder does not recommend HT-CT790 for DTS 5.1 use. It’s a 2.1 design and lacks discrete multichannel playback, making it better for general TV audio than a home‑theater surround setup. [Elektroda, nomudrek, post #16855816]
What’s a realistic starter budget to improve KD-55XE9005 sound?
The original buyer targeted PLN 1000–1200 for an entry 5.1 bar. That budget landed options like HT-RT3/RT4. Expect trade‑offs at this level, including codec support and rear‑speaker wiring. [Elektroda, Staszicu, post #16851170]
Should I audition a soundbar in store before buying?
Yes. The advice was clear: ask staff for a listening session before purchase. Real rooms and content vary, so your ears should decide. Bring a familiar movie scene to test dialogue clarity and dynamics. [Elektroda, nomudrek, post #16853618]
What return window might apply if the soundbar disappoints?
One member noted a typical 14‑day return right for individual consumers. Business purchases may differ. Check your retailer’s policy and how you bought (consumer vs invoice). [Elektroda, KOCUREK1970, post #16870268]
How do I try an optical connection step‑by‑step with HT-RT3?
  1. Connect TV optical out to the soundbar’s optical in.
  2. In TV settings, enable the optical port and select its audio format.
  3. Play a known clip and confirm the bar is the active audio device. [Elektroda, KOCUREK1970, post #16870861]
