2-Speed Dahlander Motor: Star-Delta, 3-Phase, 9-Pin, 3F System - Where to Find & Tips
tajgerbonzo. 13797 7
  • #1 16856803
    tajgerbonzo.
    I am looking for a 3f motor that works in the dahlander system, has 2 speeds and is started with a star-delta and has 9 pins. Someone had contact with such an engine and where can I find it, possibly a rating plate.
  • #2 16859770
    noplis
    Help: 36
    Rate: 49
    A little "effort" - Uncle Google will definitely help
    • 2-Speed Dahlander Motor: Star-Delta, 3-Phase, 9-Pin, 3F System - Where to Find & Tips ukad_dahlandera.jpg (23.1 KB) You must be logged in to download this attachment.
  • #3 16859794
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    Buddy, and how many outputs on the engine do you see with this uncle Google.
    tajgerbonzo. wrote:
    I am looking for a 3f engine that works in the dahlander system, has 2 speeds and is started with a star-delta and has 9 pins
    Do you want to buy or what?
  • #4 16859821
    jack63
    Help: 851
    Rate: 2822
    I have such an engine. Star - double star, 2.2kW.
  • #5 16863801
    noplis
    Help: 36
    Rate: 49
    How a two-speed motor is 6 (+ PE) :lol:
  • #6 16863836
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    tajgerbonzo. wrote:
    and is started by means of a star-delta and has 9 pins.
    So you're talking nonsense, buddy, because he has 9.
  • #7 16866135
    noplis
    Help: 36
    Rate: 49
    my culpa - I haven't read it :oops:
    And since there are 9 terminals, we have a 3- (or maybe 4-) speed motor.
    • 35f6c7b40d5643105e5527bfe68d42861ce2aa56.pdf (952.38 KB) You must be logged in to download this attachment.
The discussion revolves around finding a 3-phase Dahlander motor with 2 speeds, a star-delta starting method, and a 9-pin configuration. Users suggest utilizing search engines for initial research and share personal experiences with similar motors. One participant mentions owning a 2.2kW motor, while another clarifies the terminal configuration, indicating that a 9-pin setup typically corresponds to a 3- or 4-speed motor. A link to a relevant resource on Dahlander systems is also provided for further information.
