Magic AN-MR600 Remote Control Not Working with LG 55lf592v TV - Pairing & Connectivity Issues
Bilu19821 8172 3
  • #1 16877349
    Bilu19821
    Hello, how about the topic magic remote control AN-MR600 does not work, I have a TV LG 55lf592v TV from 2016 after pressing the ok key shows the message connect wifi / bluetooth key. Several times I tried to pair the remote control by pressing the exit button as well as using the back + home buttons. Please help. And thank you in advance.
  • #2 16895628
    pompa59
    Help: 13
    Rate: 67
    You can check the remote control in the following way: Take a mobile phone, set it to take pictures, look through it at the remote control. If the remote control is OK, you should see the LED flashing.
  • #3 16895811
    Bilu19821
    The remote control is functional but it has not been paired with the TV.
  • #4 16895834
