Unfolding LG MAGIC MOTION Remote Control (AN-MR400): Dealing with Unresponsive Circle Button
gruniu 10056 2
  • #1 16217458
    gruniu
    Rate: 178
    The circle doesn't work for me. For it to work I need to shoot quickly. I'd like to take them out and see what I can do. But with its opening I get tired.
  • #2 16217471
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    This remote control is with snaps.
  • Cleaning and regluing the rubber roller restores button operation
    #3 16217696
    gruniu
    Rate: 178
    I know, it's just a problem not to break them.
    Pilot unfolded. First, I took out the infrared diode cover. The problem was, because it needs to be bent - the risk of it breaking. Later, I was gently questioning from this cover.
    The roller (made of rubber) worked poorly because it collected fat (dirt) and slid on the plastic ring.
    I desoldered the roll, gently washed it in extraction gasoline, including a rubber ring. Then I gave budapren inside a rubber ring and waited 5 minutes. I put the eraser on a roll and left it for half a day.
    After testing, I soldered the roll and folded the pilot.
    Works like new.
    • Unfolding LG MAGIC MOTION Remote Control (AN-MR400): Dealing with Unresponsive Circle Button 20170121_214018~01.jpg (1.29 MB) You must be logged in to download this attachment.
