Sony Xperia Z3 D6603 Microphone: Quiet Functionality and Potential Reasons
Korando1245 3693 11
Why is the microphone on a Sony Xperia Z3 D6603 so quiet even though the microphone itself works when removed from the housing?
The quiet microphone is most likely caused by a blocked sound path in the display housing, not by a faulty microphone element itself. Since the mic works when it is out of the housing, the problem is probably in the inlet channel between the touch panel and the bezel, which leads out through the lower speaker mesh [#16887208] Try blowing compressed air through that area and clean all possible openings on the phone [#16887208][#16885181] If the display/LCD has been replaced, the hole may be glued or obstructed under the white mesh, so peel that mesh off and inspect whether the opening is blocked [#16887587][#16887630]
  • #1 16885131
    Korando1245
    Rate: 32
    Hello. I did not find a similar topic. I have a problem with the xperia z3 d6603, the microphone works very quietly, you have to speak very loudly so that someone can hear the same on the recorder. I took the phone apart, got into the microphone and as it turned out, the microphone works properly on the dictaphone, until I knock, I won't put in / put in a black plastic antenna that is screwed on with 2 screws. I took the mesh out of the display and it is also audible. I set up an antenna from another z3 and the same. I can't see any holes in the microphone housing. What could be the reason?
  • #2 16885181
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    First, clean all possible openings on the phone. Change the tape with the bottom microphone.
  • #3 16885188
    Korando1245
    Rate: 32
    The microphone is with all the tape. There are no holes, only a mesh hole at the bottom of the display.
  • #4 16885710
    zolwik1985
    Help: 23
    Rate: 22
    I have a similar problem on this phone. I solved it by uploading the custom kernel and editing the mixer_paths.xml files. To do this you need to have bootloader and root unlocked. This is not a solution that satisfies me 100%, but something helped there. In addition, I have the microphone noise reduction turned off because when it is activated, no one can hear me anymore.
  • #5 16885726
    Korando1245
    Rate: 32
    It seems to me that this is not the problem: / what is the plate under the plastic antenna?
  • #6 16887208
    kendzierz1
    Help: 22
    Rate: 46
    Since the microphone works after removing it from the housing, the problem lies in the "inlet channel" of the microphone in the display housing (clogged). It is located between the touch and the bezel and exits / enters through the lower speaker mesh. All you have to do is blow compressed air over there.
  • #7 16887302
    Korando1245
    Rate: 32
    But there is no hole at the point where the microphone touches the bezel. Because if there was a hole, the fault would be here, but if there is no hole in the frame?
  • #8 16887390
    kendzierz1
    Help: 22
    Rate: 46
    This is what it looked like after removing the display
    Sony Xperia Z3 D6603 Microphone: Quiet Functionality and Potential Reasons Sony Xperia Z3 D6603 Microphone: Quiet Functionality and Potential Reasons
  • Display replacement may have blocked the microphone hole
    #9 16887581
    Korando1245
    Rate: 32
    In the first photo you can see a hole on the right side of the mesh through which I guess the sound is getting through.
    On the other hand, in the second photo, the microphone is closer to the lower left corner in the white field, but it has no hole unless it's white is some foam.
    Right away, so if I had the display changed, this hole is dirty and here the problem will lie.
    So it is left to download the display and check what happened so?
  • #10 16887587
    zolwik1985
    Help: 23
    Rate: 22
    A microphone is attached to this white mesh. If you have had the LCD replaced, it is possible that the hole is stuck.
  • #11 16887622
    Korando1245
    Rate: 32
    Probably it is not possible to clean without removing the display?
  • #12 16887630
    zolwik1985
    Help: 23
    Rate: 22
    If it is as I wrote and the hole is glued, then you can peel off this white mesh and see if my theory is true. Perhaps it's not that and you can do without peeling off the display.
The discussion revolves around a user experiencing low microphone volume on their Sony Xperia Z3 D6603. Despite the microphone functioning properly when tested outside the housing, the issue persists when reassembled. Suggestions include cleaning all openings, checking for clogs in the microphone inlet channel, and ensuring the microphone mesh is not obstructed. One user resolved a similar issue by modifying software settings after unlocking the bootloader and rooting the device. The conversation highlights the importance of inspecting the display assembly for potential obstructions affecting sound transmission.
TL;DR: Most quiet-mic cases trace to 1 inlet channel between the touch and bezel; “blow compressed air” through the lower speaker mesh. [Elektroda, kendzierz1, post #16887208]
Why it matters: This FAQ helps Sony Xperia Z3 D6603 owners quickly diagnose and fix low-call-volume and recorder issues without guesswork.
Why is my Xperia Z3 D6603 microphone so quiet?
A clogged inlet channel is the top cause. The channel sits between the touch panel and bezel, exiting at the lower speaker mesh. Dust or glue from repairs can choke this path. Clear it with short bursts of compressed air aimed at the lower mesh. This restores sound to the mic without part swaps. “Blow compressed air” is the recommended first action. [Elektroda, kendzierz1, post #16887208]
How do I clean the microphone path safely?
  1. Power off the phone.
  2. Aim compressed air at the lower speaker mesh in short bursts from a few inches away.
  3. Retest calls and the recorder. If volume improves, the inlet was blocked. If not, continue with inspection of the white mesh near the mic. [Elektroda, kendzierz1, post #16887208]
Does replacing the bottom microphone flex/tape help?
Yes, technicians often replace the bottom mic flex/tape if cleaning does not restore volume. This swap addresses a damaged or contaminated bottom mic assembly. It is a straightforward hardware step before deeper disassembly. Use a quality part and proper ESD handling. Retest after replacement. [Elektroda, KRY5PIN, post #16885181]
Could my recent display replacement be the reason the mic is quiet?
Yes. After LCD service, the white mesh over the mic path can be glued or blocked, muting input. If calls are faint after a display swap, inspect that mesh for obstructions. Clearing or re-seating it often restores normal levels. “If you have had the LCD replaced, it is possible that the hole is stuck.” [Elektroda, zolwik1985, post #16887587]
Where exactly is the microphone opening on the Z3 frame?
There is no obvious hole at the mic contact point. The sound travels through an inlet channel between the touch and bezel and exits through the lower speaker mesh. Focus cleaning and inspection on that mesh and the internal path rather than searching for a visible frame hole. [Elektroda, kendzierz1, post #16887208]
Do software tweaks like mixer_paths.xml edits help call volume?
They can help, but results vary. One user improved levels by flashing a custom kernel and editing mixer_paths.xml. This requires an unlocked bootloader and root. They also disabled microphone noise reduction to stay audible. “This is not a solution that satisfies me 100%, but something helped.” [Elektroda, zolwik1985, post #16885710]
Should I disable noise reduction on calls?
Yes, test with noise reduction off. A user reported that when noise reduction was on, callers could not hear them. Turning it off improved audibility. This points to processing conflicts when the inlet is partially blocked. Toggle the setting and retest calls immediately. [Elektroda, zolwik1985, post #16885710]
Why does pressing the black plastic antenna cover change mic behavior?
Seating and pressure from the black plastic antenna cover can alter how the mic couples to the inlet path. The cover is fastened by 2 screws; misalignment can damp sound or change recorder performance. Ensure it sits flat and screws are snug, without over-tightening. [Elektroda, Korando1245, post #16885131]
Is there supposed to be a visible hole right where the mic touches the bezel?
No. The design routes sound through the internal channel to the lower speaker mesh, not a direct bezel hole at the mic. This confuses many during inspection. Clean the mesh and channel instead of hunting for a missing aperture. [Elektroda, kendzierz1, post #16887208]
Can I fix a glued white mesh without removing the display?
Often, yes. Carefully peel the white mesh to check if glue blocks the path, then re-seat or replace it. This can confirm the issue without immediate display removal. If access is limited, plan a controlled teardown later. [Elektroda, zolwik1985, post #16887630]
What is the “bottom microphone flex/tape” on the Z3?
It’s the flex assembly carrying the primary bottom microphone and related contacts. Replacing it addresses a weak or damaged mic element. Technicians use this as a practical next step after cleaning fails to restore volume. [Elektroda, KRY5PIN, post #16885181]
What if cleaning the mesh doesn’t improve volume?
Expect a deeper blockage under the display or a sealed path after prior service. You may need to remove the display to clear the inlet. One user identified the issue after a display change and planned display removal to inspect the channel. [Elektroda, Korando1245, post #16887581]
How can I tell if the mic component itself is fine?
Test the recorder with the mic out of its housing, then reassemble. If it records well outside but turns quiet when installed, the path or cover causes loss, not the mic chip. This isolates acoustic, not electrical, faults. [Elektroda, Korando1245, post #16885131]
What is mixer_paths.xml on Android?
It’s an audio configuration file that defines mixer routes and gains. Editing it can change mic sensitivity, but needs root and a custom kernel on this device. Proceed only if you understand the risks and can revert. [Elektroda, zolwik1985, post #16885710]
