[Solved] Sony Z5 Dual - The caller hears his echo (problem on my phone)
pawelhd2003 6783 4
  • #1 17048935
    pawelhd2003
    Rate: 23
    the problem is with the Z5 Dual E6633 32.4.A.1.54
    During the conversation, no matter if I made or answered the call, my interlocutor hears an echo.
    The problem disappears when the headset is connected. SIM card ok, no problems on another phone.
    I can hear the interlocutor well. The effect is as if the top microphone is picking up the sound from the top speaker and sending it back. From here, the interlocutor hears his echo, and the headphones are ok.
    New soft, full wipe uploaded
    Top microphone replaced
    Please give me some information if someone had a similar problem or indicate where on the disc which element may be responsible for it.
  • #2 17049785
    mali52
    The bottom microphone is to be replaced, and in fact it may be enough to replace the microphone seal itself. The manufacturer number is 1295-0112. This should help.
  • #3 17050625
    pawelhd2003
    Rate: 23
    I even have this org gasket. I will exchange and let you know.
    jacekjoko
    Rate: 10
    How's the situation echoing? I have the same problem, bought a new speaker but nothing helped.
  • #5 17257535
    pawelhd2003
    Rate: 23
    replacing the speaker and gasket will help. Note - seals too!
    ---> Mark my answer helpful if I helped, thanks.
