Sony Z3 Compact, Chinese Selfie Stick, Mini Jack Connection, No Sound Recording Issue, Android 6.0
pietrelcina 9918 2
  • Android 6.0 selfie stick audio compatibility issue
    #1 16586264
    pietrelcina
    Rate: 10
    I bought a Chinese selfie stick and wanted to record movies, but no sound was recorded. Stick connects to the phone via a mini jack, just like headphones. When I record a movie with headphones connected, the sound is there. I've tried everything: phone settings, recording applications and nothing has helped. I read that many people had similar problems, but I didn't find a solution anywhere. The stick is functional, because it works on the second OS phone, and not on my Android 6.0. Can you help?
  • #2 16589697
    nemo333
    Level 30  
    Help: 135
    Rate: 308
    No wonder it doesn't work since you plug it into the headphone jack and the phone treats it as a regular headset. He then uses the microphone and headphones he has plugged in. Buy a bluetooth stick that logs in as a keyboard, it won't be a problem.
  • #3 16589700
    pietrelcina
    Rate: 10
    And buddy you're wrong, because I installed the sound about app and it works now
