[Solved] Charging Syma X54HW Drone Battery with Samsung 5V 2A Wall Charger Vs Laptop Decoder
kamkamilo6 5115 2
  • #1 16913259
    kamkamilo6
    Rate: 11
    I have a question. Can I charge the battery from the syma x54hw drone with a wall charger (samsung 5v 2a) or do I have to stay charging with a laptop (I use a decoder, but also 5v 0.5a). My question comes from the fact that the battery from the previous drone (carrera) was charging with the aforementioned charger and after a long time the charger was damaged (this one not from Samsung) and the battery. Both cases I can explain the battery I was charging up to 10 times a day when it was still quite warm after removing it from the drone (yes I know it should not be done). The charger (included with the drone) was damaged from the beginning (at least I had the impression), and at the end it completely fell apart. I do not want to damage the battery, so I ask, and charging with a wall charger is really profitable, because the charging time for me was reduced from about 80 min to about 30 minutes. Thanks for all the tips.
    i.marciniak
    Help: 10
    Rate: 17
    When charging lithium batteries, the charging current should not be greater than 1/2 capacity, e.g. bat. with a capacity of 1000mA - 500mA current. Charging with a higher current will shorten its lifetime.
  • #3 17139005
    kamkamilo6
    Rate: 11
    I close the subject
