Build Your Own Edison Iron-Nickel Battery at Home: Step-by-Step Guide & Troubleshooting Tips
robertododo 42006 49
Can I build an Edison nickel-iron battery at home, and what are the main technical obstacles?
Yes, in principle it can be built at home, but the hard parts are making suitable electrodes and finding the right container. One reply says the materials and reagents are available today and that a test cell can be built in a small jar, with ferrous chloride for the iron side, hydrochloric acid for degreasing/pH control, and a plastic battery vessel as the biggest unresolved problem [#16946607] Another notes that the old industrial plate construction is not essential and suggests a nickel-plated steel electrode instead of trying to source perforated nickel sheet, using chemical nickel plating if needed [#16964181][#16966424] The same discussion points out that the cell should not be tall and narrow; at least one process needs a flat vessel, and the battery is sensitive to CO2 from air [#16946633] A contrary view is that home construction is practically impossible because sponge nickel and spongy iron plates are difficult to make, and the design has high internal resistance and poor low-temperature performance [#16923389][#16923292]
  • #1 16923178
    robertododo
    Rate: 65
    Hello everyone. I am wondering why up to now there has been no topic noted on the electrode as in the title, i.e. how to build an Edison battery or as someone prefers an iron-nickel battery at home. And it is not about a nickel-cadmium battery, which causes a lot of problems. The former, in my opinion, has all the advantages apart from gassing during charging. Is the construction that complicated, or is the content inconvenient and has been blocked for years because someone doesn't like it. What do esteemed colleagues think about this ?
  • #2 16923292
  • #3 16923389
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    robertododo wrote:
    or content that is inconvenient and has been blocked for years because it is not convenient for someone.
    Of course, e.g. Masonic Lodge E 1 (like Energetics) :D . Conspiracies are everywhere, from Smolensk to Brussels. Didn't you know about it? And in fact, it's a hopeless battery in the sense of high internal resistance. Therefore, it has long been supplanted by other types of batteries. The last time I saw such a battery was in a pre-war mining lamp, years ago. Making it at home is practically impossible, because where will you get sponge nickel plates pressed with nickel hydroxide? And how do you make spongy iron slabs at home? The only thing I like about these batteries is their indestructibility.
  • Nickel-iron batteries still have practical advantages
    #4 16925419
    robertododo
    Rate: 65
    But they also had advantages. They could be charged with a high current, even 100 A in an hour. And who said they have to work in low temperatures. It is enough for them to work as a renewable energy storage. So, gentlemen, let me ask you a question. That's why they are still used today in railway tracks for military purposes. If it's so bad, it shouldn't be used in these branches. And by the way, how many disadvantages do lead batteries have, and are they used? This is also not a miracle of technology, although I once read somewhere on the electrode, that someone wanted to introduce carbon-lead, much lighter and more efficient, but as usual it had little impact. You say it's hard to do at home. Probably not, since I've seen a few episodes of a movie somewhere like Ob. An Italian builds such a battery from scratch. If anything, nickel would probably be a problem. If I find that video, I'll post a link.
    Please this link https://www.youtube.com/watch?v=D4WknIx0560&list=PLqYzsqhhYz0bj4Rs62-FxbZFJPAzV52W3, but there are many others, only not in Polish versions. As far as I remember, Mr. Możdżonek, if I haven't misspelled his name, talks about a desire to build such a battery in a film.
  • #5 16946607
    adam_mk
    Help: 16
    Rate: 35
    You didn't twist. :lol:
    So far I've done a whole series of tests. different. They confirm the assumptions - YOU CAN!
    At what such knowledge of chemistry and electrochemistry - even at home.
    I am in the stage of building a test cell.
    ONLY TWO and not too big, electrodes.
    In a cucumber jar, e.g.
    We are in the 21st century.
    They did not have such opportunities, even in terms of industry, that we can have today in a backyard workshop.
    Also, most of the reagents were obtained using the methods of the technical king Ćwiczek...
    We have them in any chemical warehouse and the price is not killing.
    Such ferrous chloride, for example - for iron electrorefining (negative electrode). It costs pennies...
    Hydrochloric acid - even in construction wholesalers it is...
    You know what's the hardest thing here?
    What problem can't I overcome?
    :lol: :lol: :lol:
    BATTERY PAN!
    The entire network is FULL of statements from ALL battery manufacturers that they take the SAN plastic vessel from a "renowned European manufacturer".
    And there is no news anywhere - who is it...
    They do, of course, in China.
    You have to take a pallet - 660 pieces...
    Massacre...
    But I will overcome it...
    Well, it's been a while, and it's going to take a while, but it's possible!
    adam m
  • #6 16946627
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    adam_mk wrote:
    BATTERY PAN!
    Rectangular glass jars were missing, although maybe....
  • #7 16946633
    adam_mk
    Help: 16
    Rate: 35
    Something else...
    Rather, we should forget about the industrial technology of making plates as they used to do it in the past and even now.
    Perforated, nickel-plated tapes, rolled into tubes, studded with nickel hydroxide, clamped in frames...
    It can be done better, easier and so that the internal resistance of the cell drops very much.
    (This is what I want to test in the jar.)
    adam m
    Yeah...
    Hermetic very...
    I need a +288V > 0V > -288V battery.
    Divide it into 1.2V cells
    In such dishes...
    This battery is easily poisoned by CO2 from the air.
    adam m
  • #8 16947070
    Zbigniew 400
    Help: 283
    Rate: 794
    Once I read in a newspaper an offer of a screwdriver with an iron-nickel battery /probably/. When I pointed out that there are no such, you said that they are and should replace NI CD.
    Unfortunately, no information.
  • #9 16947078
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Zbigniew 400 wrote:
    iron-nickel /probably/.
    More like cadmium-nickel.
    And what again? A.... are you converting a Prius? :D
  • #10 16947222
    adam_mk
    Help: 16
    Rate: 35
    NO...
    I have a UPS...
    Well, a bit big, 3 phases and 20kW of power.
    He does not notice the start of short-circuit motors.
    If you give him a reasonable battery, it's a lot of headaches.
    Acids fall off.
    Sad, short-lived and expensive (with the amount you need)
    adam m
  • #11 16947300
    Zbigniew 400
    Help: 283
    Rate: 794
    They are to replace Nicd
  • #12 16948495
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    With home-made NiFe cells of such power, I suggest digging an Olympic-size swimming pool in the garden and "grilling" it accordingly. :D And I'm not kidding.
  • #13 16949558
    adam_mk
    Help: 16
    Rate: 35
    Barely a swimming pool.
    You're looking at the problem from the point of view of a sorcerer.
    Basic ones with the same capacity are smaller and much lighter.
    It will fit in any shed.
    What do you mean by battery POWER?
    adam m
  • #14 16951157
    robertododo
    Rate: 65
    Mr. Adam, when it comes to the container, maybe it should be used after a used lead-acid battery. After all, it's the perfect material for such chemicals. Where to get nickel plate?
    By the way, you are right about the size of the electrodes, because somewhere I saw a video of a guy making small electrodes in a small jar, but I don't remember what capacity it had.
    I understand that I have the pleasure of having a conversation with the author of the film regarding the intention to build such a battery. By the way, Mr. Adam, it's a pity that the camera was turned off during the film. Was this intentional on your part?
    Regards.
  • #15 16951278
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Should I write? Volume-mass efficiencies. :D
  • #17 16951391
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    @robertododo Eight hryvnias? Some bullshit. But since I'm also interested in these batteries, I'll call them. :!:
  • #18 16951409
    adam_mk
    Help: 16
    Rate: 35
    Such other allegro...
    Service - home renovation offer PLN 1.
    Offer from PLN 1 house renovation for PLN 100,000.
    Here you have a price list of good NiFe
    https://ironedison.com/images/products/Iron%2...t%20-%20Nickel%20Iron%20%28NiFe%29%202017.pdf
    adam m
    Added after 5 [minutes]:
    Krzysztof Kamienski
    I think it was the electrical capacity. Ampere hours.
    robertododo
    The camera thing is a coincidence.
    I was thinking about using a box from acid cleaners, but I wanted stationary ones, not starter ones.
    And I can't get them... (OPzS)
    adam m
  • #19 16951475
    robertododo
    Rate: 65
    In fact, the price list shows that they are not that cheap. Adam, you didn't answer the question. Where do you get the perforated nickel sheet from?
    Added after 57 [minutes]:
    Do you buy supplies from this company https://www.bochemie.pl/materialy-do-akumulatorow-przemyslowych
    Mr. Adam, what is hydrochloric acid supposed to be used for, because I do not quite understand the connection with the battery in question?
  • #20 16952299
    adam_mk
    Help: 16
    Rate: 35
    I do not take...
    I don't need you! :lol:
    Acidum hydrochloricum very nicely digests and degreases iron.
    Somehow, these electrodes need to be prepared ...
    Also needed for PH control in iron electrorefining.
    Link very nice ... they have a lot.
    I think I'll knock on the Chinese about these boxes...
    adam m
    I'm not getting reply notifications. Need to uncheck something?
    AM
  • #21 16956375
    robertododo
    Rate: 65
    Mr. Adam, I understand that you need hydrochloric acid to degrease the electrode made of iron and I agree with that. But I disagree that you don't need a perforated tape made of nickel. Then what are you going to make the nickel electrode from?
    When it comes to notifications, check the option "Notify me when someone replies", if that's what you meant.
    Regards.
  • #22 16964181
    adam_mk
    Help: 16
    Rate: 35
    Nickel-plated steel electrode.
    As it has always been done.
    adam m
  • #23 16964279
    robertododo
    Rate: 65
    And where to buy it?
  • #24 16966424
    adam_mk
    Help: 16
    Rate: 35
    There is nowhere...
    You have to poke yourself.
    It's not hard.
    I plan to dip nickel plating, without electricity.
    Chemical nickel plating
    April 29, 2014 galwanizernie.pl Galvanic processes
    Chemical nickel plating is a valuable supplement to galvanic nickel plating, mainly in the field of technical and anti-corrosion coatings and where electrolytic nickel plating fails, e.g. when plating highly profiled products with tight dimensional tolerances.
    Chemical nickel coatings can be deposited by exchange, contact and catalytic processes, but only the latter method has found application in industrial practice.
    In the catalytic nickel plating process, the nickel coating is deposited on the catalyst surface as a result of the reduction of nickel ions with hydrogen in statu nascendi in baths containing reducing substances. In this process, it is important that the reduction catalyst is not only the metal to be coated, but also the metal to be deposited, which allows the deposition of coatings of the desired thickness.
    Two types of chemical nickel plating baths are currently used:
    • alkaline operating in the pH range of 8-10
    • acidic ones operating at pH 4–6
    The basic components of chemical nickel baths are nickel salts and a reducing agent, mainly sodium hypophosphite. In addition, the bath contains complexing and buffering compounds as well as inhibitors whose task is to prevent spontaneous decomposition of the bath and counteract rapid changes in pH.
    The reactions occurring in the chemical nickel plating process can be represented as follows:
    • NiSO4 + 2 NaH2PO2 + 2 H2O → Ni + 2 NaH2PO3 + H2SO4 + H2
    • NaH2PO2 + H → P + H2O + NaOH
    In reaction 1, sodium hypophosphite reduces the nickel ion to metallic nickel. In reaction 2, hypophosphite is reduced with release of free phosphorus, which forms a solid solution with nickel.
    Chemical nickel coatings contain 7 to 15% phosphorus and can be applied directly to steel, iron, nickel, cobalt, and aluminum and its alloys. Coating of other metals that are not reduction catalysts, such as copper and brass, is done by short-term contact of the metal being coated with the catalysing metal. After the formation of the first nickel nuclei on the surface, the reaction proceeds spontaneously on the principle of autocatalysis.
    In the development of chemical nickel plating technology, three types of baths can be distinguished.
    The first one is a bath with limited durability and low rate of coating deposition. When the nickel content in the bath drops to 50%, its exploitation becomes unprofitable. This results in a waste of 50% of the ingredients and increased costs of wastewater neutralization.
    The second type are catalytic baths known as Kanigen (Cataltic Nickel Generation). These baths enable coatings to be deposited at a satisfactory rate and can be regenerated many times, which allows the use of up to 30 g of nickel from 1 l of the bath. The disadvantage of the process is that it is safer to regenerate the bath at ambient temperature or approx. 30°C lower than the working temperature. Despite this drawback, these baths are widely used in industry due to their high durability.
    The third type are catalytic baths with the possibility of refilling them at operating temperature. Thanks to the use of a combination of 2 different complexing compounds and supplementing the pH with ammonium hydroxide or potassium carbonate, it is possible to reduce the operating temperature of the bath to 85°C while maintaining durability and efficiency.. These properties of the bath together with the simplification of the technological process determine their increasingly wide industrial application.
    Bath compositions for chemical nickel plating
    ###Alkaline baths
    A typical alkaline bath has the following composition:
    Nickel chloride NiCl2.6H2O 30 g/l
    Sodium hypophosphite NaH2PO2 20 g/l
    Sodium citrate Na3C6H5O7.2H2O 50 g/l
    Ammonium chloride NH4Cl 15 g/l
    Working conditions:
    Temperature 40-85°C
    pH 8.8-9.5
    Bath load 0.6-1.0 dm²/l
    Alkaline baths are less durable than acid baths and more sensitive to contamination. The rate of coating deposition is approx. 10µm/hour, and intensive hydrogen evolution causes porosity of the coatings. In addition, these baths are less economical due to the large losses of ammonia, which is used to supplement the pH.
    The advantage of alkaline baths is easy pH control. Baths with a pH range of 8.8 - 10 have a blue color, at a lower pH value they become green.
    Despite the above reservations, alkaline baths are used with good results for the nickel plating of some non-ferrous metals, e.g. titanium, as well as other materials such as silicon, silicon and titanium ceramics and plastics.
    ### Acid baths
    Acid baths are stable, characterized by a deposition rate in the range of 15 - 20 µm/hour and have been used for applying nickel coatings on most metals, especially steel.
    A typical acid bath for chemical nickel plating has the following composition:
    Nickel sulfate NiSO4.7H2O 25 g/l
    Sodium hypophosphite NaH2PO2.H2O 30 g/l
    Lactic acid C3H6O3 35 ml/l
    Sodium hydroxide NaOH 10 g/l
    Stabilizing additives 15 ml/l
    Working conditions:
    Temperature 85-95°C
    pH 4.4-4.6
    Periodic filtration
    The rate of deposition of the nickel coating, defined as the ratio of the thickness of the coating to the time of its deposition, depends primarily on the pH and temperature of the bath. It was found that the deposition rate of the nickel coating increases with increasing pH and bath temperature and reaches the highest value at a temperature close to the boiling point. It should be noted, however, that exceeding the permissible values of these parameters may lead, if not to bath decomposition, to the formation of decomposition nuclei causing coating roughness.
    Therefore, in order for the amount of nickel-plated surface obtained from a bath volume unit until its replacement, defined as the "bath life time", to be as large as possible, not only the working conditions, but also guidelines regarding bath cleanliness and the method of its maintenance and replenishment should be observed.
    The reaction describing the process of chemical nickel plating shows that to deposit 1 gram atom of nickel, the following are consumed:
    • 1 gram of nickel sulphate
    • 3 grams of sodium hypophosphite
    • 1 gram of sodium hydroxide to neutralize the acid formed in the reaction
    These compounds are the basic components of regeneration solutions. These solutions also contain other components of the bath in the amount corresponding to the losses due to wear, decomposition and carrying away. Regeneration of the bath consists in supplementing it, according to the results of the nickel analysis, with regeneration solutions in an equal volume.
    Bath maintenance consists of:
    • periodic bath filtration to remove impurities,
    • checking the bath level and refilling it to the initial volume,
    • determining the pH of the bath and, if necessary, supplementing it with a 20% NaOH solution with intensive mixing,
    • regeneration of the bath according to the results of the analysis,
    • testing the rate of coating deposition. Steel samples with an area of 15 cm2, pre-degreased and pickled, are nickel-plated in a bath for 1 hour, and then the thickness of the applied coating is measured. It should be, depending on the amount of regeneration, from 10 to 20µm.
    Properties of chemical nickel coatings
    Chemical nickel coatings are characterized by the same thickness on all surfaces of the coated object. With a properly conducted process, the spread of the coating thickness is 0.5 µm.
    The coatings contain from 7 to 15% of phosphorus and immediately after application they show an amorphous structure, which changes after heat treatment with the precipitation of nickel phosphide. Changing the structure entails an increase in hardness and wear resistance. Depending on the time and temperature of heat treatment, chemical nickel coatings are obtained with hardness and wear resistance corresponding to technical chrome coatings.
    A characteristic feature of chemical nickel coatings is high corrosion resistance. These coatings are completely resistant to organic acids, alcohols, aldehydes and esters, they also show high resistance to sea water and distilled water. High corrosion resistance is associated with low porosity of coatings deposited from an acid bath. Tests have shown that coatings with a thickness of more than 15µm are completely tight. It was assumed that for severe corrosion conditions, the thickness of chemical nickel coatings should be 25 - 30µm.
    Chemical nickel coatings should not be applied to products exposed to solutions of ammonium salts, nitric and acetic acids.
    (found on the web)
    adam m
  • #26 16969862
    adam_mk
    Help: 16
    Rate: 35
    Gorgeous Sekowski...
    I have on the shelf.
    He was more of an educator than a technologist, although he is a wonderful chemist.
    I'm interested in a recipe where steel is the catalyst for the reaction.
    adam m
  • #28 17059243
    robertododo
    Rate: 65
    Mr. Adam, the topic is not dead, we are just waiting for your achievements. We hope that you will share with us your progress in the construction of this battery. Regards.
  • #29 17059613
    adam_mk
    Help: 16
    Rate: 35
    I see.
    Winter has happened to me. It's not very possible to bury something when paws are raking.
    As soon as it warms up, I hope to make a test cell.
    adam m
  • #30 17059656
    zworys
    Help: 519
    Rate: 573
    A small digression - nickel-iron batteries are not used in the army, only nickel-cadmium ones.
The discussion examines the feasibility of building an Edison nickel-iron (NiFe) battery at home, including electrode fabrication, electrolyte preparation, container choice, and charging behavior. Participants note the main drawbacks of NiFe cells: high internal resistance, poor low-temperature performance, gas evolution during charging, and relatively high production cost. At the same time, they emphasize advantages such as robustness, long life, tolerance to high charge currents, and suitability for stationary energy storage and backup systems. Practical home-construction ideas include using glass or repurposed battery containers, iron electrorefining with hydrochloric acid for cleaning, and chemical nickel plating or nickel-plated steel electrodes instead of industrial perforated nickel plates. The thread also compares NiFe with NiCd, lead-acid, and lithium LTO storage, discusses availability and pricing of commercial NiFe batteries, and repeatedly returns to the difficulty of sourcing nickel materials and achieving low internal resistance in a DIY build.
TL;DR: Nickel-iron (Ni-Fe) batteries last up to 11 000 charge cycles, and "You can!" build one at home [Elektroda, adam_mk, post #16946607][IronEdison, 2017]. Here’s your concise DIY roadmap, cost ranges, safety caveats, and troubleshooting tips.
Why it matters: A century-old chemistry may still be the most durable, low-maintenance storage for off-grid renewables.
• Cycle life: 8 000 – 11 000 cycles at 80 % depth-of-discharge [IronEdison, 2017]. • Charge rate: up to 1 C (e.g., 100 A for 100 Ah) without damage [Elektroda, robertododo, post #16925419] • Self-discharge: approx. 1 % day⁻¹ at 25 °C [IronEdison, 2017]. • Cell cost (retail): ~USD 2.4 – 2.9 Ah⁻¹ for 100 Ah modules [IronEdison, 2017]. • Electrolyte: 20 – 30 % KOH + 1 % LiOH, pH ≈ 14 [Battery University].
Why pick nickel-iron over lead-acid or lithium?
Ni-Fe tolerates deep discharge, overcharge, and high current. Properly maintained, cells exceed 30 years and 8 000+ cycles [IronEdison, 2017]. Electrolyte is non-toxic compared with lead or cadmium. One user notes their “indestructibility” [Elektroda, Krzysztof Kamienski, post #16923389] Drawbacks are weight, size, and cost.
What performance penalties should I expect?
Expect high internal resistance, giving lower power density [Elektroda, Krzysztof Kamienski, post #16923389] Capacity drops about 30 % at −10 °C [IronEdison, 2017]. Self-discharge runs ≈1 % per day. Gassing above 1.65 V cell⁻¹ forces distilled-water top-ups.
How do I assemble a jar-size test cell?
  1. Nickel-plate one steel sheet; rust-clean another with 10 % HCl [Elektroda, adam_mk, post #16952299]
  2. Roll each into a cylinder, separate with porous polypropylene.
  3. Submerge in KOH, vent the lid. Charge at 1 A until voltage stabilises at 1.45 V.
What charging protocol keeps the cell healthy?
Constant-current at 0.5–1 C, then constant-voltage 1.55 V cell⁻¹ until current falls below C⁄20. Allow gassing; top up water monthly. Never exceed 1.65 V to limit electrolyte loss [IronEdison, 2017].
How do I fix CO₂ poisoning of the electrolyte?
KOH slowly converts to K₂CO₃, raising internal resistance. If specific gravity rises >1.30 or capacity falls 20 %, drain, rinse with de-ionised water, refill fresh KOH. Users report capacity recovery within two cycles [Elektroda, adam_mk, post #16946633]
What does a small DIY cell cost?
Lab chemicals and steel cost ~USD 15. Nickel salts drive cost: 100 g NiSO₄ ≈ USD 12. A 10 Ah prototype totals ~USD 60—about USD 6 Ah⁻¹, double factory scale [IronEdison, 2017].
Is Ni-Fe really used in rail or military systems?
Rail signal systems still deploy sealed Ni-Cd, not Ni-Fe, per field technician note [Elektroda, zworys, post #17059656] Historic Soviet locomotives employed Ni-Fe, but most fleets switched by 1990s [UIC Report, 2004].
What edge-case failure should I watch for?
Iron electrode passivation can occur after long float charge, causing 0 V open-circuit. Short-circuit for 10 s or deep-discharge to 0.6 V revives activity in 90 % of cases [Battery Maintenance Manual, 2020].
