Motorolla Moto X Style: Disassembly Process and LCD-Glass Combination Explanation
toon 3708 5
  • #1 16945781
    toon
    Help: 74
    Rate: 67
    What does the disassembly of the broken glass look like, and exactly is it combined with the LCD?
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. The glass is glued to the display. The whole set of the display with the glass is replaced.
  • #3 16946395
    toon
    Help: 74
    Rate: 67
    And someone did not mention the same quick because I noticed that they are on sale
  • #4 16980234
    Pedros050
    Help: 2471
    Rate: 3927
    To do this, you need to have the appropriate service equipment, very expensive.
  • #5 16983320
    toon
    Help: 74
    Rate: 67
    I know that you need the right equipment, I just mean whether the separation of the lens itself from the LCD is feasible. I ask because in the past I had models, I do not remember what problems with separation. These were sporadic cases, but it was especially the case with LCD it is very thin.
