[Solved] LG K10 (2017) Broken Glass Replacement - DIY Hot Air Separation for Display & Quick Touch
Xenko 3138 4
  • #1 16839556
    Xenko
    Hello, I have the LG k10 2017 smartphone. Unfortunately, after a week of use, the glass was broken due to my fault (the quick touch and the display itself work). So I come with the question of how to separate the glass from the display, will I be able to do it myself without servicing, using hot air?
  • #2 16839569
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Only replacing the entire display will do nothing else at home.
  • #3 17417987
    wroteczek
    Rate: 27
    I have the same problem. After all, they only sell quick tools on the Allegro. You really can't?
  • #4 17418030
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Buy only the glass and replace it and then describe how you did.
  • #5 21373311
    Xenko
    The replacement cost exceeded the value of the phone.
