LG 43UJ620V 4K Smart TV Worth It for Bedroom? Comparing with Samsung 55 inch, Netflix & CI+ Usage
Masownik20 3660 11
Is the LG 43UJ620V 4K Smart TV a good choice for a bedroom TV used mainly for Netflix and a CI+ prepaid module, or should I buy something else?
For a bedroom TV used only for regular TV, Netflix, and a CI+ prepaid module, the thread leans more toward a simpler FHD set than the LG 43UJ620V, with Samsung M55/M56 series models such as the 43M5672 suggested as a better fit [#16950569][#16951728] Another recommendation was the Philips 43PUS6162 [#16956325] One reply said the Thomson 43UC6406 has more options than the LG, although the thread did not establish a clear technical advantage for the LG itself [#16950087] The original concern was that you already have a multimedia TV in the living room and only need a basic bedroom TV for bedtime viewing and Netflix, which is why the FHD recommendation came up [#16950115][#16951921]
  • Considering a 43-inch 4K TV for Netflix and CI+
    #1 16949384
    Masownik20
    Some time ago I bought a Samsung 4K 55 inch for the living room and I'm happy. I am currently looking for some 40-43 inch TV for the bedroom. At first I wanted TV FH, but I can see that 4K prices are already falling. The amount I have is 1600. TV is supposed to be as a tv - I have all the multimedia in the living room, so basically just Netflix and the CI + tv reader is the prepaid module because I don't want to have a decoder there. I found something like this:
    LG 43 "LED 43UJ620V Smart TV 4K.
  • #3 16950004
    Masownik20
    Somehow, I don't trust Thomson
  • #4 16950028
    Pedros050
    Help: 2471
    Rate: 3930
    Now these are no longer what was previously produced. A colleague bought satisfied.
  • #5 16950042
    Masownik20
    and this LG is worse?
  • #6 16950087
    Pedros050
    Help: 2471
    Rate: 3930
    Compare the specifications? I'm not saying it's bad but Thomson 43UC6406 has more options.
  • #7 16950115
    Masownik20
    With the fact that I have a multimedia TV in the living room here it is to be used to watch TV before bed some netflix and that's it
  • #8 16950569
    Ludwik XVI
    Help: 1325
    Rate: 788
    I would buy a Samsung M55 / M56 series for the bedroom.
  • #9 16951691
    Masownik20
    hm some specific model? but this is FH from what I see
  • #10 16951728
    Ludwik XVI
    Help: 1325
    Rate: 788
    Yes FHD
    e.g. 43M5672
  • #11 16951921
    Masownik20
    hm probably I would prefer 4k a little better picture still looks
  • #12 16956325
The discussion revolves around the suitability of the LG 43UJ620V 4K Smart TV for bedroom use, particularly in comparison to a Samsung 55-inch model already owned by the user. The user seeks a smaller TV primarily for Netflix and CI+ usage, with a budget of 1600. Responses include suggestions for alternative models, such as the Thomson 43UC6406, which some participants express skepticism about. Others recommend Samsung models, specifically the M55/M56 series, and mention the Philips 43PUS6162 as a good option. The consensus leans towards preferring 4K resolution for better picture quality, despite some suggestions for FHD models.
TL;DR: Budget set at 1600, with “just Netflix and the CI+ reader” in a 40–43" bedroom setup; LG 43UJ620V is viable, but Samsung M55/M56 and Philips 43PUS6162 also surface as contenders. [Elektroda, Masownik20, post #16949384]
Why it matters: This FAQ helps bedroom TV shoppers pick between 4K and FHD and choose models that meet Netflix + CI+ needs.
Is the LG 43UJ620V worth it for bedroom Netflix and CI+ use?
Yes, for simple bedroom use it fits the brief. The OP targets Netflix and a CI+ prepaid module without a decoder. The 43-inch class matches the stated size range and budget. If you do not need advanced gaming or premium HDR, this pick is reasonable for streaming and basic broadcast viewing. “TV is supposed to be as a tv” sums up the goal. [Elektroda, Masownik20, post #16949384]
How does LG 43UJ620V compare with Samsung M55/M56 for a bedroom?
A forum respondent recommends Samsung M55/M56 specifically for bedroom duty. That suggests strong everyday usability for FHD sets in this role. If you value a simpler FHD set and room-friendly performance, consider the M55/M56 recommendation. For 4K preference, look back to LG or other 4K models discussed. [Elektroda, Ludwik XVI, post #16950569]
Which exact Samsung model was proposed?
The suggested exact model was Samsung 43M5672. It belongs to the M56 family referenced for bedroom use. This narrows shopping and helps compare prices against the LG 43UJ620V and other 43-inch options. Quote: “Yes FHD e.g. 43M5672.” [Elektroda, Ludwik XVI, post #16951728]
Should I choose 4K over Full HD at 43 inches here?
The OP prefers 4K, noting a “little better picture.” If you stream Netflix and sit close, that aligns with a 4K choice. If cost or simplicity matters more, the Samsung FHD suggestion remains valid. Decide based on budget and distance. [Elektroda, Masownik20, post #16951921]
Is Thomson 43UC6406 a good alternative at a similar price?
One user claims the Thomson 43UC6406 “has more options.” However, the OP expresses brand trust concerns. That is an edge case to consider when prioritizing features over perceived reliability. Quote: “has more options.” [Elektroda, Pedros050, post #16950087]
What if I don’t trust Thomson as a brand?
Brand trust matters. The OP says, “Somehow, I don’t trust Thomson.” If you share that view, focus on LG, Samsung, or Philips from the thread. Shortlist models with proven support and availability in your region. [Elektroda, Masownik20, post #16950004]
Is there a Philips 43-inch model recommended in the thread?
Yes. A contributor calls out the Philips 43PUS6162 as “very good.” That adds a 4K alternative beside LG for bedroom streaming and broadcast use. It also broadens your brand choices without changing the size or budget direction. [Elektroda, Anonymous, post #16956325]
Will Netflix run fine on these choices for casual bedroom viewing?
The use case is light Netflix streaming before sleep. The OP keeps heavy multimedia in the living room. In this context, any of the cited smart TVs should cover Netflix basics without external boxes. CI+ handles pay TV duties separately. [Elektroda, Masownik20, post #16949384]
Can I use a CI+ prepaid module instead of a decoder here?
Yes. The plan is to use a CI+ prepaid module and avoid a set‑top box. Ensure your chosen TV includes a CI+ slot and your provider supports your specific module. This reduces bedroom clutter and keeps setup simple. [Elektroda, Masownik20, post #16949384]
What budget was set, and what does it imply?
The budget is 1600. That frames a mid‑range 43-inch short‑list across LG, Samsung FHD, Thomson, and Philips suggestions. Expect baseline smart features and acceptable streaming performance at this price point. Prioritize picture and app stability. [Elektroda, Masownik20, post #16949384]
Is the LG 43UJ620V considered worse than alternatives?
The OP asked if LG is worse. Replies did not state it was bad. One user said the Thomson had more options, while another suggested Samsung for bedrooms. LG remains viable for the stated needs. [Elektroda, Masownik20, post #16950042]
How do I quickly choose among LG 43UJ620V, Samsung 43M5672, and Philips 43PUS6162?
Use this 3‑step filter:
  1. Confirm Netflix and CI+ slot meet your needs.
  2. Decide 4K (LG/Philips) versus FHD (Samsung 43M5672).
  3. Match price to the 1600 budget and preferred brand trust. [Elektroda, Masownik20, post #16949384]
