Volvo V50 2.0D DPF - Leaping Exhaust Pressure (31-52 hPa) & DPF-Related Bugs in Idling
sly_1978 13137 2
  • #1 16967504
    sly_1978
    Help: 34
    Rate: 284
    The car throws a few DPF related bugs. In the idling parameters, the pressure difference is from 31-52 hPa, but it jumps within 5 seconds in more or less these values.
  • #2 16967521
    highlanderus
    Level 30  
    Help: 174
    Rate: 186
    You probably have a damaged DPF sensor mounted on the left side of the battery.
  • #3 16972830
    sly_1978
    Help: 34
    Rate: 284
    No Eolys supplement completed and reset. Fap cleared and also reset. The pressure has dropped to 4 mBar and it fluctuates only slightly.
