HP LaserJet P1102w_wifi inst. - Printer installation - connection via wifi. Prin
Anja04 13869 4
  • Need to connect HP P1102w to Wi-Fi network
    #1 16970940
    Anja04
    Good morning,
    I'm trying to connect the HP P1102w printer via wifi. Software and drivers installed without problem, but a test page did not print. The problem is, I was unable to connect the printer to the wifi network. A blue light is blinking on the printer, which (apparently) indicates that there is no connection. I tried to connect via WPS but without success. The printer is not in the list of devices connected to the router.
    I don't know much about computer science, so I am asking for tips on how to solve the problem in a simple way.
  • #2 16971389
  • #3 16971511
    Anja04
    Unfortunately, I didn't have a CD. The printer is in use. Software downloaded from hp and installed. There was no problem at this stage. The problem is with the connection of the printer to the router
  • #5 16972570
    Anja04
    Thank you, but I did it before ;)
    The problem was solved by changing the security settings of the Wifi network.
    Changed from WPA-PSK / WPA2-PSK to WPA2-PSK.
