How can I find the Wi‑Fi password for an HP LaserJet M14-M17 printer?
The password is not on the laptop; when the installer asks for a password, it means the printer’s Wi‑Fi password. On a ready printer, hold the button with the cross/exclamation mark until the power light starts blinking, then print the settings page, where the Wi‑Fi password should be listed [#17734561][#20198207]
Yes, but this is done through the router. The router broadcasts a signal and creates links. Here, the router - laptop and router - printer. You would use the laptop - router - printer radio link. What version of Windows do you have on your laptop? What router do you have?
On the laptop, when I turn on the WIFI, it shows me the printer and that it is password-protected. And I have a tiny Huawei router from Plus. And Windows is Windows 10 [/url]
When the installer asks for a password, it is the WIFI password, not the printer's password!
When the printer is ready press and hold the button with the cross until the power light starts blinking, a settings page will be printed, if there is any additional password, it should be there.
Boy, don't mislead her, the printer has ad-hoc wifi and you can connect to it without a router, the ssid Hp is normally displayed and characters, depending on the model, everything is described on the hp website, unfortunately the hp website does not write where the password is and also needs it
You need to hold down the button with the exclamation mark in the triangle. The printer settings page will print. I will also have the password for Wi-Fi there.
The discussion revolves around locating the Wi-Fi password for the HP LaserJet M14-M17 printer. Users initially suggest that the password is typically found on the router, but the original poster clarifies they need the printer's Wi-Fi password specifically. It is noted that the printer can connect directly via ad-hoc Wi-Fi without a router, and the SSID is displayed. To retrieve the password, users recommend pressing the button with the exclamation mark in a triangle to print a settings page, which may contain the necessary Wi-Fi password. Additionally, the importance of distinguishing between the router's password and the printer's password is emphasized. AI summary based on the discussion. May contain errors.
