HP LaserJet P1102w Connectivity Issue with ASUS K56C: Printer Requires User Interaction
joshabel 2880 3
  • #1 16568722
    joshabel
    I am unable to print documents from ASUS K56C to HP LaserJet P1102w. The message "Printer requires user interaction. Printer requires your intervention." The printer works neither via USB nor wirelessly. The printer has already been installed and uninstalled several times. The installation process is successful each time, but attempts to print anything are unsuccessful.
    I will add that the printer works with ASUS K70IC without any problems.
    Please help.
  • #2 16582392
    kiss39
    Help: 397
    Rate: 636
    And you have selected the HP LaserJet P1102w printer option as Default, set it and check if it prints.
    Control panel> Hardware and sound> Devices and printers> The cursor selects the printer, i.e. "HP LaserJet P1102w" PM, expand and select "Set as default printer"
  • #3 16582711
    joshabel
    Yes, sure, that's what it's set up. This is unfortunately not it.
    Thanks for speaking up. Maybe some other clue?
  • #4 16582873
    pawelcb33
    Help: 11
    Rate: 124
    Download the latest drivers for your printer system and when installing drivers again manually enter the path to the files you will need. Don't install the entire package
