[Solved] Volvo V50 1.6D 2009: Reduced Engine Power at 3,000 RPM Post-Turbocharger Regeneration
cordel1 13821 2
  • #1 16971166
    cordel1
    Rate: 13
    I have a problem with mine Volvo V50 -1.6D - 2009year - DPF cut out . Two weeks ago I regenerated the turbocharger and the week went great. Now when accelerating, e.g. on a cold engine, it goes well for a while, then the message reduced engine power appears and I cannot exceed 3 thousand. rpm in a given gear. The service in which I repair the car stated at the moment that all the parameters from the mechanical side are ok, they changed the turbine / EGR valves, nothing helps, the turbine charges the power excessively. The service stated that the problem may be on the electronics control side. I am asking for suggestions what else can be done, where to look for the problem.
  • #2 16971384
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6404
    If you have an error table turned off, activate it again and then fix it.
  • #3 17007873
    cordel1
    Rate: 13
    Unfortunately, the problem is not solved
