Connecting Two House of Marley Chant Mini Bluetooth Speakers for Stereo Playback
MrConrad 7446 5
  • #1 16973160
    MrConrad
    Hello!
    I have 2 House of Marley Chant Mini speakers. These are bluetooth speakers with a 3.5mm jack female socket. Is there any possibility of connecting them to play stereo? If so, what equipment will I need for this?
    barton21
    Help: 79
    Rate: 192
    If you want to connect them with a 3.5mm jack this is an option. To do this, you need to have 3 jacks and a shielded cable (2 core wires, which is the screen)
    nomudrek
    Level 36  
    Help: 406
    Rate: 472
    These speakers have an additional AUX input on the mini jack which allows you to connect other signal sources, only in this way will it be possible to use two speakers in a stereo sound system.
  • #4 16973930
    MrConrad
    And a guitar cable with an output to the right and left channel + 3.5mm jack adapters?
    barton21
    Help: 79
    Rate: 192
    The cable is good, you only need to have it terminated on one end with one jack plug 3, and on the other with two connectors
  • #6 16974865
    MrConrad
    OKAY. Thanks to everyone for the answers. The problem is solved and the thread is closed.
