Control Home Sound System: Switch Between 5 Indoor & 2 Terrace Speakers using Relay
shulc1 2583 6
  • #1 14583967
    shulc1
    Rate: 17
    Hello, as in the subject, I am looking for a solution to the problem of home sound control. I need a relay that can be used to disconnect the 5 speakers in the house and attach 2 that are on the terrace.
  • #2 14584149
    sosarek
    Help: 9320
    Rate: 15535
    Is it not simpler to give a signal for a separate amplifier?
    Z
    Pka, Poznań, 60-850
  • #3 14584196
    marian133
    Help: 426
    Rate: 572
    These 5 speakers are home cinema?
    If so, each KD receiver has a front column selector.
    Stereo amplifiers also have this, depending on the model.
  • #4 14584920
    shulc1
    Rate: 17
    This is a home cinema set. In the set we have 5 outputs for the loudspeakers we have 7 speakers, so we have four speakers connected to the same output. I thought about the nap-dope company's drivers nap rop-01 would solve the matter of switching the signal to the speakers on the terrace, but there is still a problem how to turn off the other three speakers?
  • #5 14585113
    sosarek
    Help: 9320
    Rate: 15535
    Connecting other speakers than dedicated to an integrated home cinema system can lead to damage to the power amplifiers, but you also have an example of a transmitter that is not suitable for this purpose. Does the cinema have any analogue audio outputs?
    Z
    Pka, Poznań, 60-850
  • #6 14588046
    marian133
    Help: 426
    Rate: 572
    shulc1 wrote:
    This is a home theater set. In the set we have 5 outputs for the loudspeakers we have 7 speakers, so we have four speakers connected to the same output.
    So you do not have two pairs of front terminals (read the output selector).
    In that case you will have to plug in and unplug the speakers manually, or buy an additional speaker amplifier on the terrace. I do not see any other option.
  • #7 14588064
    azibik
    Level 32  
    Help: 82
    Rate: 324
    Bluetooth. Portable speakers and cinema transmitter.
    Added after 48 [second]:
    I recommend BOSE SoundLink Mini.
The discussion revolves around controlling a home sound system with 5 indoor speakers and 2 terrace speakers using a relay. The user seeks a solution to switch between these speaker sets. Responses suggest that using a separate amplifier for the terrace speakers might be simpler. Concerns are raised about potential damage to the power amplifiers when connecting non-dedicated speakers to an integrated home cinema system. The user mentions considering the nap-dope company's drivers (nap rop-01) for switching signals but faces challenges in disconnecting the other three speakers. Recommendations include manual switching or acquiring an additional speaker amplifier for the terrace. A Bluetooth solution with portable speakers is also suggested, specifically recommending the BOSE SoundLink Mini.
