Whirlpool AWO / C 61003P Washing Machine: Error F27, Spin Program Issues & Tacho Troubleshooting
JacekArtur1 7158 2
  • #1 16543275
    JacekArtur1
    Rate: 56
    Hello. Ladies and gentlemen, please ask for advice because I have a mixed washing machine experience :) Well, my washing machine that I got to fix and use crashes after starting the spin program error F27 as in the subject. Earlier it had seized bearings but I was able to fix it. And now ticks the relays moment on the spin and after a while throws out this error. It does not move the drum or centimeter in any direction. I've talked to several programmer repairers and I know that this could be a programmer or engine fault. I connected the motor to a 20 Volt DC power supply from the laptop adapter and spins. Unfortunately, by connecting a generator to the tacho, the multimeter does not detect any voltage. I removed the tacho cover and no damage can be seen. Tacho has a resistance of 69 OM. Or maybe it gives impulses and not tension? And now the question is whether the fact that the engine after connecting to the power supply works allows you to clearly state that it is in good working order? Motor resistances between pins are in the order of 2-3 OM exactly I can measure if necessary. Unfortunately, I have nowhere to substitute for a second engine because I do not repair professionally, but rather as a hobby.
    Which other motor can be substituted for a CESET MCA 38-64 148 WHE21 380 watt check? Regards Jacek.
  • #2 16543311
    michal9119
    Help: 8
    Was the measurement made using an AC voltage meter and when turning the motor? I suggest you first check the contact on the ankle from the engine and the beam.
  • #3 16691882
    JacekArtur1
    Rate: 56
    I apologize for such a late reply but I have to explain to you that the reason for the fault was WRONG programmer plug. Therefore, I sensitized all DIY enthusiasts to take pictures of how plugs are fitted. I have improved and it works.
