Momo7w Tablet with Windows 10 Home: Permanently Disabling Update Assistant with Limited Disk Space
Macbak 26874 15
How can I permanently stop Windows 10 Home Update Assistant from reinstalling on a 16 GB tablet with too little free space for the update?
To stop Update Assistant from coming back, disable or delete its scheduled tasks in Task Scheduler and then uninstall the assistant [#17077789] Search the scheduler for entries related to “WindowsUpdate” and the Update Assistant (entries starting with “Assistant...”), and remove or disable all of them; after that, the assistant should no longer relaunch on its own [#17077789][#18158558] A more drastic fallback is to block NTFS permissions for the “Windows10Upgrade” folder on the C: drive so it cannot save, download, or install there [#17125700] The registry policy `NoAutoUpdate=1` and stopping the Windows Update service were suggested for Windows Update itself, but the thread reports they did not stop the Update Assistant by themselves [#16976508][#16977996]
  • #1 16975892
    Macbak
    Rate: 29
    I have a Momo7w tablet with Windows 10 Home. This tablet has a disk capacity of only 16 GB. After installing Windows and the most-needed programs like chrome, skype, ccleaner, etc., only 3.66 GB of free space remains.
    As we know Windows 10 Home very much limits the ability to turn off the update and I still get the Update Assistant to the latest version of Windows 10.
    I can not install this update because it requires 8 GB of free disk space, and I only have 3.66 GB.
    I used to turn off the updates in the control panel in the services and it worked, but now it has stopped working, i.e. works for a while, and some time later the assistant is packaged again and tries to download and install.
    I am asking for advice on how to get rid of it, for sure there is a way, for example, through burial in the registry, because I am not interested in postponing the update or changing the time of installing them.
    Thank you in advance for your help
  • #2 16975984
    polmark2
    Help: 31
    Rate: 15
    By. M $ automatic updates can be disabled in versions from PRO up, and in the HOME version it is impossible. Maybe some good people have found a way - I will gladly find out.
    elecol
    Rate: 9
    It will of course be given by the registry editor:
    1. Run the registry editor
    2. Go to HKEY_LOCAL_MACHINE \ SOFTWARE \ Policies \ Microsoft \ Windows
    3. Create a key named WindowsUpdate and go to it
    4. In WindowsUpdate, create an AU key
    5. Create a DWORD value named NoAutoUpdate by changing its value to 1
    And of course, restart the computer
    Let me know if it worked
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    https://www.oo-software.com/en/shutup10 - this software has the function of tamping updates in Windows 10 (by the way, you can still cure a few other things, although it's worth knowing what's going on in it - in the program itself there are descriptions possible to modify functions).
  • #5 16976548
    Macbak
    Rate: 29
    Thanks very much for hints, I did:
    - I have reset the settings to the initial state (I reinstalled removing all files and settings)
    - I uninstalled the Windows 10 update assistant (it installed immediately after installing the system)
    - In the control panel in the tab "System and security" >> "Administrative tools" >> "Services" >> "Windows Update" changed the status of the service to "Stopped" and the type of startup to "Disabled"
    - Then I clicked on the magnifying glass (in the taskbar), in the search field I wrote "Settings" then "Update and security" >> "Advanced options" and here I deferred the update
    - Now, like "Settings" above, I chose "Network and Internet" and set the connection properties to use the tariff connection (to limit the amount of data downloaded, including updates)
    I do not know if and how much it will help, but for now it does not download updates. Probably help temporarily, for 10 or 35 days (I do not remember what time there was a postponement period), so just in case I set up that I use the tariff connection (Maybe this will prevent me from downloading updates on my network). If not, I will try with this register, and if it does not help, then I will use this program from dt1. Either way, thanks for the hints :)
    PS: If you have other proven ways to block the update, then write :) I will be watching and in a while I will let you know if it works and what works.
  • #6 16977348
    dt1
    Help: 7315
    Rate: 8292
    Stopping the update service should be enough (at least in older versions, enough, I have done so on one laptop for over a year and there is silence).
  • #7 16977996
    Macbak
    Rate: 29
    Unfortunately, my actions have not worked, the update assistant is still packing and wants to install updates. Editing the registry also did not help. It looks like these methods have affected the other updates, but not the assistant.
    Replacing the update assistant's .exe file also did not help. Every now and again, it gets redone and changes my file. Any ideas yet?
    Boosterpl
    Help: 19
    Rate: 33
    I am currently testing Windows Destroy Spy to completely get rid of the update, anniversary update etc. - I have a 16gb tablet (dedicated to the camera view) and nothing is pushed into it and all the time it pulls off despite being turned off in the background. I released this program and hacks what is ok:
    http://www.majorgeeks.com/mg/getmirror/destroy_windows_10_spying,1.html
    BOOSTNET Usługi Informatyczne Grzegorz Bednarski
    Okrzei 3m9, Jelenia Góra, 58-500 | Tel.: 665XXXXXX (Show) | Company Website: www.boostnet.pl
  • #9 17077789
    Macbak
    Rate: 29
    Thanks for the information about the program, I will also try with him. The most important thing is to get rid of the permanent Update Assistant, because the windows update itself is a puff, but this assistant is unbeatable so far :)
    EDIT: 24/03/2018
    Unfortunately, the program did not get rid of the update assistant and even if I removed it manually, it was downloaded again and installed, but I managed to effectively kill it and get rid of both its and other updates :)
    Well, yes, for Windows Update, I described above how I beat it, and when it comes to the Update Assistant, it's quite a simple way. Namely, he turns on at a specific time, this is due to an entry in the task schedule. Click the magnifying glass on the taskbar, enter the "Task Scheduler" and look for and kill all entries related to "WindowsUpdate" and the Update Assistant (they probably start with the entry "Assistant ..." or something like that). You can delete or disable these entries, I deleted them just in case :)
    Then we remove the Update Assistant and once again should not install. I hope someone will find this topic useful :)
  • #10 17125700
    Boosterpl
    Help: 19
    Rate: 33
    Brilliant! I did not think that the schedule of tasks in the microsoft list is the windows update item - I deleted all files.
    Previously, I did an even more drastic thing that worked. Namely, I blocked completely the NTFS permissions for the folklore "Windows10Upgrade" on the C: drive. Then nothing could be saved, downloaded or installed there :)
  • #11 17142902
    natalia.dun
    Hey.
    I have the same problem, but on the ultrabook - a micro disk. Could someone write step by step what to do. I see here a lot of ideas, but what actually worked and what is unnecessary? Thanks in advance for your help. Te updaty to masakra: /
  • #12 17146514
    Macbak
    Rate: 29
    Do everything that I wrote in my second post in addition to this
    Macbak wrote:
    - I've reset the settings to the initial state
    And then do it
    https://www.facebook.com/photo.php?fbid=1669208896501202&set=p.1669208896501202&type=3&ifg=1
    https://www.facebook.com/photo.php?fbid=1669209199834505&set=p.1669209199834505&type=3&ifg=1
    These screenshots are just an example of how to select an entry and delete or disable it. You need to find the ones that have something in the WindowsUpdate and assistant name (I do not remember) :D
  • #13 18157016
    lucrum.cesans
    Rate: 98
    I am conquering the subject.
    I need to update my 7 Home win to 10 for professional reasons ...
    Are there 100% working options to disable updates?
    Thanks in advance
    LC
  • Disable Windows Update tasks to stop Assistant запуск
    #15 18158558
    Macbak
    Rate: 29
    I don't know what it is like now, the old tablet has fallen and I have a new one with updates installed and a larger disk.
    Try disabling Windows Update in the control panel as described above, and then delete all entries related to Windows Update in the task schedule. As I showed in the pictures, just instead of "Adobe Flssh Player" search there for "WindowsUpdate" and "Assistant" or "Asistant", I do not remember exactly :)
    And the Assistant will not start anymore, because it will not be scheduled to run, and Windows Update will also be turned off and nothing should install updates.
    In these photos with the arrows above, I showed the entry "Adobe Flash Player", because I had already removed entries related to updates, and you look for this Assistant and Windows Update. Turn off or delete everything that has this name in it.
  • #16 18159044
    lucrum.cesans
    Rate: 98
    Thanks,
    on days I will try :)
    @Macbak
    Your snapshots are no longer available.
    FB says:
    Sorry, this content is currently unavailable
    The link used may have expired or the page will only be visible to a group of recipients you do not belong to.
    Return to previous page ? Go to news ? Visit our Help Center.
The discussion revolves around the challenges faced by users of the Momo7w tablet running Windows 10 Home, particularly regarding the inability to disable the Windows Update Assistant due to limited disk space (16 GB total, with only 3.66 GB free). Users share various methods to prevent the Update Assistant from downloading and installing updates, including registry edits, disabling services, and using third-party software like ShutUp10 and Windows Destroy Spy. Despite attempts to stop updates through the control panel and task scheduler, some users report that the Update Assistant continues to reinstall itself. Effective solutions include modifying registry settings, disabling scheduled tasks related to updates, and blocking NTFS permissions for specific folders.
TL;DR: On 16 GB Windows 10 Home tablets, upgrades may need 8 GB free while only ~3.66 GB remains; fix by removing Update Assistant tasks. “Stopping the update service should be enough.” [Elektroda, Macbak, post #16975892]
Why it matters: This FAQ shows how to stop forced upgrades when you don’t have space, without buying new storage—ideal for Momo7w and similar low-capacity devices.
How do I permanently stop the Windows 10 Update Assistant on a 16 GB tablet?
Uninstall the Assistant, then open Task Scheduler and delete or disable all WindowsUpdate and Update Assistant tasks. Remove the Assistant again if present. This prevents scheduled relaunch and background reinstalls. Users report the Assistant stops returning after these task deletions on space‑limited devices. [Elektroda, Macbak, post #17077789]
What registry change disables automatic Windows Update in Home?
Run regedit and create HKLM\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU. Add NoAutoUpdate (DWORD) = 1. Restart the device. This sets a policy that blocks automatic downloads, useful when disk space is tight. “Let me know if it worked.” [Elektroda, elecol, post #16976508]
Does stopping the Windows Update service alone work?
In older builds, setting the Windows Update service to Stopped and Disabled could be sufficient. One contributor noted, “Stopping the update service should be enough,” and kept a laptop quiet for over a year. Your results may vary on newer builds. [Elektroda, dt1, post #16977348]
Why does Update Assistant reinstall after I delete its EXE?
Scheduled tasks and related components can recreate the executable and re-trigger downloads. Simply replacing or deleting the EXE fails because the system restores it. Remove the scheduled tasks first, then uninstall the Assistant to prevent reinstalls. [Elektroda, Macbak, post #16977996]
Can setting a metered connection and deferring updates help on small SSDs?
Yes. Set your network as a metered connection and use Advanced Options to defer updates. One user combined this with disabling the Windows Update service to delay downloads for up to about 35 days and reduce background data use. [Elektroda, Macbak, post #16976548]
How much free space do I need for a feature upgrade on these tablets?
Expect about 8 GB free space for major upgrades. A typical 16 GB tablet can have only ~3.66 GB free after basic apps, which blocks upgrades. Clearing Update Assistant tasks prevents repeated failed attempts on such constrained devices. [Elektroda, Macbak, post #16975892]
Is fully disabling updates possible in Windows 10 Home without upgrading to Pro?
Home lacks official controls to fully disable automatic updates. Contributors highlight that Microsoft enables full disablement starting at Pro. Workarounds exist (services, tasks, registry), but Home provides no sanctioned master switch. [Elektroda, polmark2, post #16975984]
How do I remove Update Assistant scheduled tasks? (3-step How‑To)
  1. Open Task Scheduler and search for "WindowsUpdate" and entries starting with "Assistant".
  2. Disable or delete each matching task.
  3. Uninstall the Windows 10 Update Assistant and reboot. This sequence prevents the assistant from auto-starting again. [Elektroda, Macbak, post #17077789]
Are tools like O&O ShutUp10 or DWS useful here?
They can help harden settings that limit updates and telemetry. One recommendation is O&O ShutUp10, which includes switches to tamp updates and tweak privacy options. Use carefully and review each switch’s description before applying. [Elektroda, dt1, post #16976518]
What about using Destroy Windows 10 Spying (DWS)?
Some users test DWS to block the Update Assistant and related components. It can automate host, service, and task changes. Always create a restore point before use, as aggressive toggles may affect Store or driver delivery. [Elektroda, Boosterpl, post #17077666]
Is blocking the C:\Windows10Upgrade folder a viable workaround?
Yes. Deny NTFS permissions on C:\Windows10Upgrade so the system cannot write or reinstall the Assistant there. One user reports this stops downloads and installations in that directory on a 16 GB device. [Elektroda, Boosterpl, post #17125700]
What are the risks or failure cases when disabling updates?
The Assistant may reappear if scheduled tasks remain, and manual EXE deletion fails because Windows restores it. Security patches also stop when updates are disabled, so plan manual patch windows. Remove tasks first to avoid reinstallation loops. [Elektroda, Macbak, post #16977996]
Do these steps work on ultrabooks with tiny internal storage?
Yes. Users with ultrabooks and micro‑sized disks face the same constraints and can apply the same task, service, and registry methods to prevent forced upgrades due to low space. [Elektroda, natalia.dun, post #17142902]
I can’t see the screenshot examples—what happened?
The original Facebook links for the screenshots expired or now restrict access. The Task Scheduler method still applies; follow the text steps instead to locate and remove WindowsUpdate and Assistant tasks. [Elektroda, lucrum.cesans, post #18159044]
Are these tips still relevant after 2019?
Yes. Even after device changes, the author advises the same approach: disable Windows Update, then remove WindowsUpdate and Assistant tasks. This continues to stop the Assistant from launching on later setups. [Elektroda, Macbak, post #18158558]
