Kiano Slimnote: Windows Installation Error, Partitions Dropped, Updates Issue, Need Help
qrch4k 8541 4
  • #1 17028732
    qrch4k
    Kiano Slimnote: Windows Installation Error, Partitions Dropped, Updates Issue, Need Help Kiano Slimnote: Windows Installation Error, Partitions Dropped, Updates Issue, Need Help Please help, I get an error while installing windows on Kiano. I dropped partitions, I want to do everything again. After the files are copied by the installer, he starts to install the updates and at this point it pops up that he has encountered an error and must restart: / HELP ME :)
  • #2 17028792
    safbot1st
    Help: 2719
    Rate: 1585
    qrch4k wrote:
    pops up that he met an error
    But which? I don't really understand how the system installs updates since the network is not connected. Offline?
    You haven't even written what OS ... :(
    In addition, updates are installed on the 32GB eMMC "micro-disk", where every MB is at a premium.
    I don't understand why you are buying these toys. No LAN, terrible wi-fi, uh ...
  • #3 17028819
    qrch4k
    [Quote = "safbot1st"]
    OS is Windows 10, I didn't buy this crap, it's just a toy of my friend's children. I was hoping it would be a simple system installation but something is wrong, so I asked for help
    safbot1st
    Help: 2719
    Rate: 1585
    This is an error of the sdbus.sys driver - probably managing the eMMC bus.
    https://h30434.www3.hp.com/t5/Tablets-and-Mob.../HP-ENVYX2-SD-Bus-inetrnal-error/td-p/3277097
    How did you prepare the eMMC memory for installation?
    W10 requires 20GB of free space, for the 64bit version. What OS are you installing?
    MS writes: For devices with small disk space, e.g. 32 GB disks, or older devices with previous generations of disks, upgrading may require additional memory. During the upgrade, detailed process instructions will appear. You may need to delete unneeded files from your device or connect a USB flash drive to complete the upgrade process.
    Maybe the Chinese know how to install W10 on this "padaka" and at home gymnastics is necessary.
    Try W10 32 bit.
  • #5 17028891
    qrch4k
    It worked when installing Windows 8.1
