[Solved] Lenovo yoga300 32GB 11'6inch - Insufficient memory for updates
ewuta68 8598 7
  • #1 17115562
    ewuta68
    I have a Lenovo yoga300 32GB with Windows 10 preloaded and I have a problem with disk space because the system requires an update that has as much as 8 GB and I do not have that much on the disk. Is it possible to increase this memory or the laptop-taablet is suitable for scrap? I know that the memory card is soldered to the motherboard. Please give me a constructive answer, I'm a complete layman. Thank you in advance for any info Ewka
  • #2 17116536
    sasad
    Help: 9
    Lenovo yoga300 does not have a HDD? What model is it ? What processor, ram, how many /.
  • #3 17116584
    ewuta68
    Ram has 2 GB, Celeron processor, HDD
  • #4 17116711
    sasad
    Help: 9
    I checked a similar model and I do not see the possibility of expanding the computer except for the so-called external drive to the USB port. There is also such an option and just give up the Win 10 upgrade and disable the update, just search on Google. And for simple needs, all you need is a windows firewall and windows antivir for safe internet.
  • #5 17117062
    icosie
    Help: 298
    Rate: 239
    Download some program to view the folder structure on the disk in this laptop.
    E.g: WinDirStat
    After scanning, take a screenshot of the window and put it here on the forum as an image.
    You can probably get a few GB by cleaning the disk thoroughly.
    Then he will be able to install patches and updates. The entire update will be less than 8GB because the space needed is installation files + updates. After the update, cleaning again and you won't even see that something was done.
    The question is he wants to throw updates that they take up so much space?
  • #6 17117639
    ewuta68
    Thank you very much, I will do it. The system says that if I do not install this update, the system will turn off. I found out that I bought the service, not the system, so I am forced to install these updates, and installing another system may fail because I thought about it too. you can sell something like that ?
  • #7 17117675
    Karaczan
    Help: 869
    Rate: 1128
    Unfortunately, the "disk" capacity of such devices is a complete misunderstanding
    I've been through this with Asus. You had to take 64GB ;)
    In addition, Win10 with its constant updates can grow very quickly.
    Do a system cleanup, mark any copies after updates etc ...
    If there is still a shortage of space, you will need heavier equipment.
    I recommend Dism ++ https://www.chuyu.me/en/index.html " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://www.chuyu.me/en/index.html
    In cleansing, highlight anything that is not orange and give it some time.
    It should be enought.
  • #8 17150210
    ewuta68
    I will advertise the goods because it does not meet the expectations.
The Lenovo Yoga 300, equipped with 32GB of storage and running Windows 10, faces a significant issue with insufficient disk space for system updates, which can require up to 8GB. Users suggest potential solutions, including utilizing external USB drives for additional storage, performing disk cleanup using tools like WinDirStat and Dism++, and disabling unnecessary updates. The discussion highlights the limitations of low storage devices, particularly with Windows 10's frequent updates, leading some users to consider selling the device due to its inadequate performance for their needs.
