Best Set of Pots Under PLN 500 for Gas Stove - 5L Minimum, No Pan Required
WSRH 9102 8
  • #1 16981465
    WSRH
    Rate: 62
    Hello, gentlemen, like a simple thing and yet you need to choose something reasonable, namely a set of pots, up to PLN 500. There must be one big pot, 5L is the minimum, I don't need a pan. Pots for the ordinary gas stove.
  • #2 16987112
    Borutka
    Help: 125
    Rate: 414
    If you don't buy the cheapest Tesco and Chinese pseudo producers available on the Allegro, it's probably hard to buy something wrong with gas. Personally, I buy at Ikea. In Duka, on the other hand, I tried the induction pan. Unevenly fried and went to complaint. Replaced and the next one the same. I bought it at Ikea for a penny and it works fine. I also have elegant enamel pots from Olkusz and I'm also happy.
  • #3 16988480
    jaro41
    Help: 83
    Rate: 45
    Review Berghoff's proposition
  • #5 16990390
    Borutka
    Help: 125
    Rate: 414
    Gerlach apparently begins to return to the roots after the episode with Chinese trash. But it would probably be best to take them at least.
  • #7 16990502
    Borutka
    Help: 125
    Rate: 414
    For my part, I can only advise you from an autopsy (especially if you are circling among inexpensive pots) ... it is better to choose pots with riveted handles.
    I use enamel pots for cooking soups.
    I would not go so far below the budget and near this price you can really choose something (Berghoff, Telal, Ikea, Olkusz, and maybe Gerlach)
  • #8 16993988
    WSRH
    Rate: 62
    And the matter of color changes of these pots, in each model it is that it changes color or the bottom is slightly rusted? because I see in reviews, even those for PLN 1,000 have it
  • #9 16996883
    Borutka
    Help: 125
    Rate: 414
    Buy yourself an induction hob and the pots will be like new. Discoloration and deposits of gas combustion products are probably the norm. And not only pots, but everything in the vicinity of the gas hob is trusted. As for the rest of the utility features of induction, there will be only pluses.
    I have not encountered rust on pots. It is true that a cheap pot can only be coated with a more precious material, and underneath it can be rusting sheet metal.
The discussion centers around selecting a set of pots for a gas stove, with a budget of PLN 500 and a minimum capacity of 5 liters. Participants recommend avoiding low-quality brands like Tesco and certain Chinese manufacturers. Notable suggestions include purchasing from Ikea, Berghoff, and Gerlach, with emphasis on choosing pots with riveted handles for durability. Concerns about discoloration and rusting are addressed, with advice that such issues are common with gas stoves, and that induction hobs may mitigate these problems. Links to specific products are shared for further consideration.
