Mercedes W202 Airflow Issue: Intermittent Fan, Voltage Variations, Resistor Control & Panel Test
KRZYSIEK* 7041 3
  • #1 16981614
    KRZYSIEK*
    Rate: 122
    The problem with the air supply started that once it worked, once it did not, but now it has completely stopped working. I checked the fan power supply and it turns out that there is current on 2 thick wires and a voltage from 12v to 6v on the third thin cable from the resistor control (depends on how the knob is set on the supply), but if I connect a 5w bulb to this thin wire And now the question is whether it would result from a damaged panel, which is the airflow control knob. The fan is functional because it works for a short time. the fan power cube consists of 3 wires, 2 thick and one thin.
  • #2 16981665
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    I wrote about it before - the W202 with a traditional key has a COMPLETELY DIFFERENT ELECTRICAL SYSTEM than the W202 with a "fish" key - this information is not available again, and in this case it is very important. The thin cable is only the voltage that controls the airflow - there is not enough current there to light the bulb. The voltage across it should vary from about 0.5 volts for a minimum to about 7 volts for full power. It is the other way around with you - you have not measured it in terms of the plus?
  • #3 16981708
    KRZYSIEK*
    Rate: 122
    from what I remember it was 5v on the first gear on the last 12v
  • #4 16995250
    KRZYSIEK*
    Rate: 122
    The fan resistor was the fault of the lack of air supply. It should be of some use to someone. 3 wires go to the fan, the side wires are power, i.e. ground and + after ignition, the middle wire is fan control. I will write what voltage I had from 2 fan control panels. In the first gear it showed me a second panel of 9.94v on one 10.16v panel. Fifth gear 5.59v second 4.59v panel. On these 2 panels the fan is working normally.
