[Solved] Mercedes w203 C180 2002 2.0 Gasoline: Unresponsive Heating, Ventilation and Airflow Control
krystian199729 15513 3
  • Faulty HVAC control knob or actuator suspected
    #1 16703360
    krystian199729
    Rate: 13
    Hello. A few months ago I bought a Mercedes car in 203 2002 2.0 gasoline recently when cooler nights came I noticed that it was taking warm heat despite the presentation of zero reaction temperature, no matter if the engine is warm or cold neither can I control the air supply because it does not work despite turning the knob the airflow does not change . The airflow adjustment works properly. Any ideas what could be wrong?
    Pawel wawa
    Help: 1262
    Rate: 4432
    krystian199729 wrote:
    I bought it a few months ago
    So it can be anything, If you don't undress, you won't find out. In case of repair, unprofitable repair, for pennies you can buy functional used lumber.
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    The airflow direction and temperature are adjusted by means of flaps and stepper motors that control them. From the control panel you can do a system test and calibration. Search the forum 203 (Polish) - everything is there.
  • #4 17082456
    krystian199729
    Rate: 13
    the problem is solved
    the cause was damaged panel control cable just behind the plug.
    soldered wires. problem solved
    Thank you for your help.
