VW Passat b5 - supply fan not working, no voltage in the engine
Darek-Mrk 15639 4
  • #1 17251537
    Darek-Mrk
    the fuse has been checked immediately is ok
    the airflow does not start at any position of the knob
    no voltage in the cube from the motor the tube was checked [/ center]
    Strumien swiadomosci swia
    Help: 1404
    Rate: 6417
    Manual or climatronic, like climatronic is a hedgehog to check, and a power relay in both cases.
  • #3 17465377
    mulp
    Rate: 16
    Hello, similarly - passat b5 estate 98r, and zero airflow - and winter is coming :( , does anyone have any idea - how to diagnose it - fuse 25 (30A) is ok.
    and yet - I have already turned the fan off - and it is connected to the battery :|
  • #4 17465950
    Launch78
    Help: 22
    Rate: 162
    whether the supply air control knob has a supply or a functional resistor in the resistor
  • #5 17466444
    CyberZdzislaw
    Level 4  
    I had a similar experience, resetting the climatronic panel helped me. has youtube there are videos on how to do it.
