SKoda Octavia 2 - FOXWELL NT510 Tester: DPF Burning, Diagnostics, Parameters & Features
jarek~~ 6228 12
Can I use a Foxwell NT510 to regenerate the DPF on a Skoda Octavia II 1.6 TDI, and does it show useful DPF data like differential pressure and fill level?
The thread says the 1.6 TDI can regenerate the DPF while standing still at about 1000 rpm, and you should let the cycle finish because the fans switch on briefly near the end [#16987140][#16989409] For VAG diagnostics, the advice is to buy a VAG-specific tool such as VAS/VAG rather than a universal scanner [#16987140] One user also reported idle regeneration values around 0.6–0.7 and said the engine speeds up during burn-off [#16989409]
  • #1 16981702
    jarek~~
    Rate: 12
    Hello, I'm planning to buy a tester for home use that would be useful for diagnosis and simple repairs in the garage, and for burning DPF. I was searching the internet and I found nothing else for a price of up to PLN 1,000. I am interested in how this miracle actually works and whether it really has an efficient DPF firing function, and whether it provides any DPF parameters, e.g. differential pressure, filling. The device will be used primarily on Skoda Octavia 2 FL 1.6TDI. What is burning in this tester? Is it firing at a standstill or while driving?
  • #3 16981893
    jarek~~
    Rate: 12
    Can you write something more about him? time license? What car brands can it support? and what model exactly to buy? is it complicated about service?
    Added after 47 [minutes]:
    and what do you say about it:
    NEW CDP + PRO 3in1 ver. 2017 NEC GW12M + 8 Adapters at Allegro price PLN 960
  • #4 16987140
    andrzej20001
    Help: 1578
    Rate: 6669
    1.6tdi burns beautifully even at a standstill, it has ~ 1000rpm. You just don't quench it, it finishes slowing down and finto. For diagnostics of the vag group, simply buy vas, vag, etc.
  • #5 16987211
    Boryc2014
    Help: 21
    Rate: 90
    And I was thinking about such equipment. I don't have a temporary license, it updates itself. Over 60 brands of passenger cars and over 30 trucks. Equipment is the best for me. Expensive but expense for years.
  • #6 16989366
    jarek~~
    Rate: 12
    Thanks for the information, and approximately what momentary combustion can I expect at idle with burned DPF?
  • #7 16989409
    andrzej20001
    Help: 1578
    Rate: 6669
    0.6 -0.7 is with me, you can see that burns out after revolutions. When it burns it turns on the fans for a moment and end.
  • #8 16989479
    leonov
    Help: 1039
    Rate: 2247
    Of course, all CDP + clones are, the software is the same, it makes cars until 2014, it has different versions (one or two discs and of course the quality of assembly and components). Universal scanner for personal buses and TIRs.
  • #9 16989946
    jarek~~
    Rate: 12
    and is it worth investing in such a clone? no problems with them? They work just like the original ones, e.g. do some functions in the software not work? And if it's worth it, which one will be the best? from what I've read, I already know that double-disc with Japanese relays, but maybe some specific models are worth attention?
  • #10 16990042
    leonov
    Help: 1039
    Rate: 2247
    As I wrote, there are two models, it all depends on the assembly and quality of parts, with warranty and after the case. As for operation, if everything is good, they work comparable to the original, the limitation is also soft until 2014. You can also search the portals of the yellow Launch Easydiag full version X431 at a similar price to 1 thousand.
  • #11 16992272
    jarek~~
    Rate: 12
    Thanks for the information, I have one more question, not so directly about the heads but related to the subject (I think) it is about OBD2 codes. Namely, I am thinking of making a simple on-board computer that would communicate via OBD2 and display various information. Through some codes I was able to receive information, but unfortunately not all work. I suspect that manufacturers just change them and to get information you need to know "hidden" PID codes. Is there a chance to know the codes for:
    temperatures: turbine, DPF and oil; RPM for the turbine; state of filling DPF; data from DPF pressure sensors could be useful; fuel level in the tank. Perhaps someone has already tried to listen to communication, e.g. Wireshark, between the computer and the head?
  • #12 16992901
    andrzej20001
    Help: 1578
    Rate: 6669
    You have a bup headup plugged into the diagnostic socket. Or on a cell phone
  • #13 16993830
    jarek~~
    Rate: 12
    I have already watched these devices and they do not meet my expectations, with software. on the phone is a little better but they also lack the functions I am looking for
The discussion revolves around the use of diagnostic testers for the Skoda Octavia 2 FL 1.6TDI, particularly focusing on the FOXWELL NT510 and alternatives like the Autocom Delphi CDP. Users inquire about the efficiency of DPF burning functions, diagnostic capabilities, and the parameters provided by these devices, such as differential pressure and DPF filling levels. It is noted that the DPF can burn effectively at idle, with specific RPMs mentioned. Users also discuss the merits of clone devices versus original models, highlighting the importance of build quality and software compatibility. Additionally, there are inquiries about OBD2 codes for various vehicle parameters, indicating a need for deeper diagnostic capabilities.
TL;DR: On Octavia 2 1.6 TDI, forced DPF regen can run at ~1000 rpm; an expert notes it “burns beautifully even at a standstill.” [Elektroda, andrzej20001, post #16987140]
Can the Skoda Octavia 2 1.6 TDI perform a stationary DPF regeneration?
Yes. Users report the 1.6 TDI completes forced regeneration while idling around 1000 rpm. Do not shut it off mid-process; let revs drop to normal when finished. “Burns beautifully even at a standstill.” [Elektroda, andrzej20001, post #16987140]
Should I stop a regeneration early if I’m short on time?
No. Avoid interrupting a regen. The advice is to not quench the engine; allow the cycle to finish and idle to return to normal. Premature shutdown risks incomplete soot oxidation. [Elektroda, andrzej20001, post #16987140]
What instant fuel consumption should I expect during idle regen?
Expect approximately 0.6–0.7 l/h indicated during an idle regeneration. The cooling fans may switch on briefly, then turn off when the process completes. [Elektroda, andrzej20001, post #16989409]
How do I trigger and monitor an idle DPF regen on 1.6 TDI?
  1. Connect a VAG-capable tool (e.g., VAS/VAG) and start the service regen.
  2. Keep the engine idling; target is about 1000 rpm.
  3. Wait until revs settle and fans cycle; do not shut off early. [Elektroda, andrzej20001, post #16987140]
Is FOXWELL NT510 required, or should I use VAS/VCDS for VAG cars?
Thread advice favors VAG-native tooling (VAS/VAG) for diagnostics and service tasks on the Octavia 2. This ensures access to brand-specific functions like DPF service procedures. [Elektroda, andrzej20001, post #16987140]
Are Autocom/Delphi CDP tools a good long-term buy under PLN 1,000?
One user calls the equipment “best for me,” noting it self-updates, lacks a temporary license, and supports 60+ car brands and 30+ trucks. It’s pricier, but seen as a years-long expense. [Elektroda, Boryc2014, post #16987211]
What model years do CDP+ clones typically support?
According to user reports, CDP+ clone software generally covers vehicles up to about the 2014 model-year. These are universal scanners for passenger cars and trucks. [Elektroda, leonov, post #16989479]
What should I look for when buying a CDP+ clone?
Quality varies by assembly and components. Choose units sold with a warranty. Some buyers prefer double-board designs with Japanese relays. Software remains the limiting factor. [Elektroda, leonov, post #16990042]
Is there a Launch X431 option near PLN 1,000?
Yes. A suggested alternative is the yellow Launch Easydiag X431 (full version) around PLN 1,000, offering broad brand coverage at a similar price. [Elektroda, leonov, post #16990042]
Will budget tools read DPF metrics like differential pressure or soot load?
The thread seeks these parameters but recommends VAG-specific tools for VAG cars. Use VAS/VAG-class software to access brand-specific DPF data reliably. [Elektroda, andrzej20001, post #16987140]
Can I build my own OBD2 computer to read DPF temps and soot load?
Expect gaps using only standard PIDs. The OP notes some PIDs don’t work and suspects OEM “hidden” PIDs. Custom readers need those proprietary codes to show DPF temps or soot load. [Elektroda, jarek~~, post #16992272]
Is a phone app or plug-in HUD a workable display for basics?
Yes. A user suggests a plug-in head-up display or a smartphone app via the diagnostic port for simple readouts. Feature depth varies by app. [Elektroda, andrzej20001, post #16992901]
What’s a quick sign that regen is ending at idle?
Users observed the cooling fans may come on briefly during the cycle, then shut off, and idle speed returns to normal when finished. [Elektroda, andrzej20001, post #16989409]
What is VAS/VCDS in this context?
These are diagnostic tools for VW-Audi Group vehicles. The thread advises buying VAS/VAG-class tools for accurate VAG diagnostics and service functions. [Elektroda, andrzej20001, post #16987140]
What is CAN bus?
Controller Area Network (CAN) is a robust vehicle network standard that lets control units communicate without a central computer. It underpins OBD-II data exchange. “CAN bus”
