#1 16988002 25 Jan 2018 16:51 qazae qazae Level 7 Posts: 5 Rate: 2 » | Topic author Post #1 16988002 25 Jan 2018 16:51 There is no backlight in the watch above, I don't know if it's the battery's fault or a factory defect? I will add that I have had it since purchase.
#2 16988038 25 Jan 2018 17:08 HD-VIDEO HD-VIDEO Level 43 Posts: 8040 Help: 1265 Rate: 1885 » | Helpful post? (+3) Post #2 16988038 25 Jan 2018 17:08 If you use the backlight constantly, the battery will discharge quickly. Go to ZIBI and see if it works the same way in another copy
#3 16998703 29 Jan 2018 22:50 qazae qazae Level 7 Posts: 5 Rate: 2 » | Topic author Helpful post? (+2) Post #3 16998703 29 Jan 2018 22:50 Unfortunately, in other watches it shines better, I don't know anymore, maybe it's a factory defect. And this could not be replaced?
