LG 42LA620S TV - No Backlight Issue, Individual LED Check, Power Supply Voltage (EAX64905301)
kuba_n 14985 13
Why does the LG 42LA620S have sound and a faint image but no backlight, even though each LED lights individually with batteries and the LED output is about 118 V instead of the expected 157.5 V?
The LED strip fault is not excluded: the LEDs in this panel are connected in series, so a bad LED, bad contact, or bad connection between the two 5-LED halves can still stop the backlight even if each LED seems to light on a battery test [#16755811] [#16756120] Check the strips with a proper LED tester or by powering them as a string, not only with AA batteries [#16775342] On the PSU/driver side, the likely area is the MAP3202 backlight driver circuit and Q803; one answer recommends replacing Q803 and improving the soldering around MAP3202 and the transition between LED halves [#16760166] Another diagnostic clue is that the MAP3202 control/feedback voltages should be checked; in the thread the OVP/FBN readings were noted and the driver was considered suspect when the backlight stayed off [#16758709] [#16760362] In short, the low 118 V output points more to a driver/protection or interconnect problem than to a proven-good LED string [#16755773] [#16760166]
  • #1 16755735
    kuba_n
    I have a LG 42LA620S TV in which the backlight does not work. The image is (you can see it shining in the matrix with a flashlight), the sound also. At the beginning I checked the status of the LEDs - visually they all looked ok. However, I decided to check each LED separately with two AA batteries. Each LED is on individually.
    The next step was to examine the voltage at the power supply with the LED connector (EAX64905301 power supply). An example photo of this power supply is below:
    This is a 42-inch TV, so this connector should be 157.5V. Instead, when the TV is turned on, the output voltage to the LEDs is around 126V (EDIT: Exactly 118V).
    If each diode works separately, can a diode fault be excluded? Unfortunately, I don't have any LED testers to check if they work all together.
    Greetings,
    Cuba
  • #2 16755746
    mirex
    Help: 1950
    Rate: 1990
    Disconnect the backlight, connect the meter to + LED and ground, turn on the TV. Enter the result.
  • #3 16755773
    kuba_n
    The voltage after disconnecting the backlight is the same, exactly 118V - the same as when the backlight was attached (I waved about these 8V in the first post).
  • #4 16755811
    lisek
    Service technician RTV
    Help: 6363
    Rate: 6895
    What matrix?
    How many LED lines, how many LEDs in the line, how connected.?
    What about the control signal on pin.1 MAP3202 from main ... through the transistor
    This model of the power supply (your photo) is
    - LGP3739-13PL1 EAX64905301 (2.3) with LED driver for MAP3202
    In 42: LG with this PSU was matrix LC420DUE (SF) (R1)
    -5x line of 10_LED> 50x LED (3-3.5V) which gives approx. 150-170V
    :idea: time between field Q401 and MAP output is an additional PNP 2907A 60V / 0.6A 0.4W transistor link
  • #5 16755842
    kuba_n
    The matrix in this TV is LC420DUE (SF) (U2).
    There are 50-5 lines of 10 LEDs in total, of which two halves of 5 LEDs each (as you wrote).
  • #6 16756120
    lisek
    Help: 6363
    Rate: 6895
    There, the LEDs are connected in series!
    Look at this bipolar what I wrote, field
    - transitions between the "halves" of the Led lines
  • #7 16758709
    kuba_n
    MAP3202 has 2.48V on 1 pin. 11.9V is on 2 pins (VCC).
  • #8 16758754
    mirex
    Help: 1950
    Rate: 1990
    Revelation! Keep it up.
  • Q803 transistor has no voltage on any pin
    #9 16758937
    kuba_n
    I use the scheme available here http://www.go-gddq.com/upload/2015-09/15091816267835.pdf on page 19.
    I checked the Q801 transistor and after switching on the TV on the drain-source connector I have 120V. According to the specification available here: https://4donline.ihs.com/images/VipMasterIC/IC/ADPO/ADPOS00529/ADPOS00529-1.pdf, the maximum voltage on this connector is 200V.
    On the other hand, the Q803 transistor has no voltage on any of the connectors (collector-base, collector-emitter and emitter-base).
  • Replace Q803 and check MAP3202 pin voltages
    #10 16760166
    lisek
    Help: 6363
    Rate: 6895
    Replace Q803, improve soldering to MAP, see the transition between the halves of the lines (purge) and it should be ok.
    ps
    What do you have after the pin. OVP and FBN?
    Read the datasheet of this MAP3202 link
    Example voltages with damaged Q803
    2 - 11.3
    3 - 1.2
    6 - 2.94
    8 - 4.94
    9 - 9.5
    10 - 1.1
    11 - 2.85
    12 - 2.35
    13 - 0.73
    14 - 0
  • MAP3202 pin voltages and OVP/FBN readings checked
    #11 16760362
    kuba_n
    Thank you for your answer. The voltages on individual MAP3202 pins are as follows:
    1 - 2.48
    2 - 11.89
    thirty
    6 - 2.97
    8 - 4.94
    9 - 0
    10 - 1.45
    11 - -0.34
    12 - 0.72
    13 - 0.64
    14 - 0,
    so on OVP I have 1.45V and on FBN 0V.
    Solders on MAP3202 at first glance seem fine:
    Even today or tomorrow I will drive after Q803, solder, clean the transitions between led halves and let me know if it worked.
  • #12 16775342
    adizas
    In your place, I would check the diodes again, but not with the batteries, only for the power supply.
  • #13 16776843
    kuba_n
    Q803 replaced, but no backlight yet. The voltages on the power supply are also the same as before the exchange. I looked at the diodes again. I attach a photo of my "suspect":
    For comparison, the second LED without a "cap".
    Can the LED on the left be a potential culprit for the lack of backlight? In its upper left corner a brown "dot" is visible, which is not next to the diode on the right.
  • #14 16777267
    radsat
    Moderator
    Help: 470
    Rate: 209
    Please stop further work and have the equipment serviced.
    3.1.17. Do not send very basic questions that can be found in the instruction manual or publicly available sources. Do not take the attitude that I deserve. Keep the level of questions and discussions. Thank you.
    https://www.elektroda.pl/rtvforum/topic2869272.html
The discussion revolves around a malfunctioning LG 42LA620S TV, specifically a backlight issue where the image is faintly visible under flashlight but no backlight is operational. The user confirmed that all individual LEDs function correctly when tested with batteries. However, the power supply voltage measured at the LED connector (EAX64905301) is significantly lower than expected, at 118V instead of the required 157.5V. Various troubleshooting steps were suggested, including checking the MAP3202 control signal and examining the Q803 transistor, which was later replaced without resolving the issue. The user also suspected a faulty LED due to visible damage. The discussion emphasizes the importance of checking the entire LED circuit and power supply components for faults.
TL;DR: Example fault data: MAP3202 pin 1 ≈2.7 V when Q803 is bad; “Replace Q803… and it should be ok.” [Elektroda, lisek, post #16760166]
Why it matters: This FAQ helps DIY techs diagnose no‑backlight faults on LG 42LA620S (EAX64905301) quickly and safely.
What usually causes no backlight on an LG 42LA620S with EAX64905301?
Most cases trace to the LED driver stage or the LED strings. This model uses MAP3202 with five series lines of ten LEDs. A failed switching transistor or an open LED segment prevents current flow, so the screen stays dark while audio works. Checking the driver enable/control and the series pass devices is the first step. [Elektroda, lisek, post #16755811]
What voltage should I see on the +LED line when it’s healthy?
With 50 white LEDs in series (3–3.5 V each), expect roughly 150–170 V under regulation. The driver boosts to meet LED string Vf plus headroom. If you read far lower with a connected, known‑good load, suspect an open segment or driver fault. [Elektroda, lisek, post #16755811]
I measure about 118 V on +LED even with the backlight unplugged. What does that indicate?
A static ≈118 V with the harness disconnected shows the boost converter is starting but not reaching the normal regulation range. That behavior matches a fault state or missing feedback/current path. Confirm enable/feedback pins and the switching devices. [Elektroda, kuba_n, post #16755773]
How do I test the LED boost safely without the strips?
Try this quick check: 1. Disconnect the backlight plug. 2. Put your meter from +LED to chassis ground. 3. Power on and log the voltage. This verifies the boost output without stressing the strips. “Disconnect the backlight, connect the meter… Enter the result.” [Elektroda, mirex, post #16755746]
Which components commonly fail in this PSU’s LED driver?
Q803 is a known offender. Guidance in the thread is to replace Q803, reflow MAP3202 joints, and clean/inspect the via transitions between half‑strings. Many techs restore backlight after this step. “Replace Q803… and it should be ok.” [Elektroda, lisek, post #16760166]
What do MAP3202 OVP and FBN readings mean here?
Reported values were OVP ≈1.45 V and FBN 0 V during the fault. That points to the controller not seeing proper feedback/current, keeping the system in protection or low‑drive. Check sense resistors, Q803, and LED continuity. [Elektroda, kuba_n, post #16760362]
How are the LEDs arranged in the LC420DUE (SF)/(U2) panel?
There are five lines of ten series LEDs. Each line is split mechanically into two halves for layout, but the halves run in series electrically. An open anywhere breaks the whole string. [Elektroda, kuba_n, post #16755842]
Can AA‑battery testing prove my LED strips are good?
No. Individual LEDs can glow on AA cells yet fail under real current and voltage. Use a proper LED tester or the TV’s regulated boost with current limit to validate strips under load. “Check the diodes again, but not with the batteries.” [Elektroda, adizas, post #16775342]
I see a LED with a brown dot under the lens. Is that the culprit?
A thermal spot under the lens often signals a stressed or open LED. However, if you’re unsure or inexperienced, stop and seek service to avoid panel damage. Forum moderation advised handing it to service at this stage. [Elektroda, radsat, post #16777267]
What MAP3202 supply and enable values were observed during diagnosis?
Measured values included VCC ≈11.9 V and Pin 1 (control/enable) ≈2.48 V. These confirm the controller is powered and nominally enabled, shifting focus to switching devices and feedback path. [Elektroda, kuba_n, post #16758709]
What were the Q801 and Q803 readings during the fault snapshot?
Q801 showed about 120 V D‑S after power‑on, within its 200 V rating. Q803 showed no measurable voltages, consistent with a defective switch or drive issue. This directed the later replacement of Q803. [Elektroda, kuba_n, post #16758937]
Why is MAP3202 pin 1 control important in this set?
Pin 1 receives a control signal from the main board via a transistor stage. If this enable path is missing or low, the driver limits or stays off, causing no backlight. Verifying this control is a key diagnostic step. [Elektroda, lisek, post #16755811]
