Audi A4 B5 (1996) 1.6 Petrol - Intermittent Starter Issues & Electrical Reset in Cold & Frost
JaCuS0808 8820 10
Why does my Audi A4 B5 sometimes not crank in cold weather and reset the radio and trip counter when I turn the key?
A bad main power/ground connection is the most likely cause, especially the corroded battery-to-body ground cable, so clean or replace the battery-body-engine grounds and test by temporarily jumpering battery minus directly to the engine block [#16990656][#16991063][#16991981][#16992941] The jumpy voltage readings also point to an intermittent connection rather than a healthy charging system, and one reply notes that a battery with an internal broken plate or loose clamps can behave this way too [#16990656][#16991054] You should also measure the alternator output against the battery voltage and check the charging fuse on the battery feed, because there is a fuse in the black fuse box on top of the battery and it may be burnt [#16993127][#16995854] If the battery is being discharged by short trips or loads like the blower/lights, that can make the problem show up more often, but 10 minutes on a charger is not a full charge [#16990732]
  • #1 16990638
    JaCuS0808
    I have a problem with my car, specifically with electrics. Audi A4 B5 1.6 Petrol 96 year Namely, as outside it is Cold and Frost outside at about 0 to -5 and below it the Starter does not turn. As if the Battery was not supplying Current to the Starter. It does not happen constantly only once in a while ok for two months. When I turn the key, it resets my Radio and turns it off completely to the Factory settings, and the car counter also resets. You can hear 3 short Sounds. If he doesn't want to start and connect the battery to the charger for 10 minutes, he will start without anything. Similarly, it happens when the Car turns on the Vent and comes from 10-20 minutes with the engine turned off and the ignition key turned on and the lights in the Car either passing or lights in the Headliner. I really don't know what to do anymore and where the problem lies. I checked the battery charging:
    At a standstill:
    -12,28V
    With the engine running:
    -14.00V and jumps up to 6.00V
    With the engine running with the Windscreen heating on, High beam (Long), Air flow on max:
    - 13, 38V and also jumps up to 4.00V
    I didn't check the alternator because I don't know how to connect it with a Multimeter
    Do you know what could be wrong with him?
  • #2 16990656
    spinacz
    Help: 1204
    Rate: 2651
    Maybe the battery has a torn off plate and once it is ok and other times not, maybe the ground or power cables at the battery can clamp.
  • #3 16990732
    nikusert
    Help: 699
    Rate: 1754
    Hello .
    Measure the battery after these few minutes of running the airflow, with the engine off. You can also switch on the dipped headlights instead of the blower. If after these few minutes the lights fade or go out, it can mean that the battery is ending its life. If you drive short, short distances, it can be that the battery is quite discharged.10 minutes under the rectifier, it is very little to fully charge it. If the battery is not age, then connect it for at least 10 hours. Of course, it does not hurt to check the clamps, mass (battery-engine), as well as power consumption at standstill.
  • #4 16991054
    JaCuS0808
    But the measurements show that the battery is good. The measurement jumps are puzzling
  • #5 16991063
    robokop
    Help: 1763
    Rate: 6370
    To check the battery weight-> body-> engine.
  • #6 16991981
    JaCuS0808
    The cable from the mass going from the car body to the battery is a bit corroded. I had water drains clogged and once there was water and corrosion entered the conduit. Could this be the reason? And can I connect the ground wire to another place?
  • #7 16992941
    nikusert
    Help: 699
    Rate: 1754
    What problem do you have to clean the ground cable (battery - body, battery motor). If the starter does not turn, then connect the battery minus the motor, for example, quickly by firing leads. Measure the voltage during firing on the battery, and the second measurement in this way;
    1 meter tip to (+) battery
    2 meter tip to engine body
  • #8 16993101
    JaCuS0808
    I took the Battery measurement. OK
    But the measurement shows that there is no charging. The measurement stopped at 13.76 V under load (lights, air flow, etc.) and jumped to 0.90 V
  • #9 16993127
    nikusert
    Help: 699
    Rate: 1754
    Make a measurement on the alternator, what is the difference from the measurement on the battery. There should be a fuse on the battery from the alternator. Check this place, it may be burnt.
  • #10 16995709
    JaCuS0808
    Where's the fuse?
  • #11 16995854
    nikusert
    Help: 699
    Rate: 1754
    Is the battery box black with fuses.
✨ The discussion revolves around intermittent starting issues with a 1996 Audi A4 B5 1.6 Petrol, particularly in cold weather conditions. The user reports that the starter fails to turn, resembling a lack of current from the battery, and experiences resets of the radio and car counter. Various suggestions are made, including checking the battery for corrosion, ensuring proper grounding connections, and measuring voltage under load. The user notes that the battery appears to be functioning but shows no charging under certain conditions. Recommendations include inspecting the alternator and checking for a fuse related to the alternator's connection to the battery.
